  • How can make a electronic based door lock
    Updated: Oct 26, 2024
    Views: 1.3K
    How can we make this door lock so that you can operate it by a text message or phone call(signal)...Need Suggeestions please
  • Anand Tamariya
    MemberMar 16, 2013
    There are various interface design/boards available which will generate a TTL logic high on receiving a text message, phone call or any other sensor. Use this input on one pin of microcontroller (uC). Based on this momentary signal, uC will make another pin high(and keeps it high - this is important!!). This pin can be connected to a transistor to trigger a solenoid. The solenoid pulls the latch opening the door!!
  • Jeffrey Arulraj
    MemberMar 18, 2013
    Use DTMF that is the commonly used tool for this remote control thing and it is easy to implement as well
  • Hamza Immurana
    MemberMar 19, 2013
    Anand Tamariya,Thanks for the contribution i will be glad if you can elaborate on the uC
  • arunchary
    MemberMar 20, 2013
    we have door lock technology in various concepts. but coming to the device, you can notice across the ATMs we have a magnetic device where it can get magnetized using 12v supply and logic can be done using microcontroller so it will be un magnetized and magnetized acording to ur inputs like GSM operated, DTMF ,zigbee,RFID ,smartcard etc. so mainly you need to go for selection of Door Sensor.
  • Anand Tamariya
    MemberMar 20, 2013
    Hamza Immurana
    If you haven't worked on uC(micro-controller) before, that in itself is a big project.
  • arunchary
    MemberMar 20, 2013
    idnt get you anand..
  • Anand Tamariya
    MemberMar 21, 2013
    arunchary
    You should pick up controlling LEDs using a micro-controller as your project.
  • Syed Mohammed Ali
    MemberMar 27, 2013
    Hamza Immurana
    Use of microcontroller is a good option better u choose arm7 or max232
