@jeffrey-xA7lUP • Oct 16, 2012
Removing these stuffs will increase the speed to an extent only and not too much
For better results try to improve your RAM capacity in your system that can be a permanent short term solution -
@abhishek-fg9tRh • Oct 16, 2012
wanna Increase speed?
yeah! that's possible, it is called OC (Overclocking).
The frequency of processor set by company is safest, but you can increase it & enjoy better performance than stock speed.
But remember, it will void warranty of processor ; also if you're not fully technically understanding how this OC shit is done, then DONT DO ! You might end up hurting your hardware.
OC is usually done in Processor & GPUs. -
Can a OC tut be sent by PM TSH need it to be done in my lap -
Dude, I am using cell atm.
I will send you on Sunday, if you dont mind.
Btw if you've Asus laptop it can be damn easy, I've noticed that Asus motherboards are safely easily clockable. -
Real col man I have a HCL one and waiting for Sunday do say this is possible but I think Ill check your mail by wednesday and tell how feasible that will be to me -
Man, i cannot guarantee anything.
I've seen 2.93 GHz processor OCed to 4 GHz. some works awesome & some are Overheated.
Depends upon the place you live, no. of fans in Cabinet & how much you OCed.
There is certain line you must not cross it 😉 -
Sure all points taken into prime consideration it is out of warranty so no worries about that and all pal -
@rahul69-97fAOs • Oct 16, 2012
Overclocking is possible but risky, A better way is to go for a clean format, it may increase the speed to some extent. Other ways are using tools for registry cleaning, etc. -
Everything worth doing is risky !
If you're planning to OC, buy Black edition MoBos & Processors. They are specially designed for OCing purpose. -
@thebigk • Oct 16, 2012
Over-clocking is risky if you are doing it for the first time and don't really (and exactly) know what you're doing. But there are few tips that can make your computer work faster -
- First, clean up your HDD; remove the unnecessary files from the partition in which your operating system is installed (mostly C: )
- Check your task manager and permanently kill the services and processes that you don't need.
- If you can, upgrade the RAM of your computer.
- Turn off unnecessary graphics.
- Make sure that your system tray does not have unwanted applications running.
- Keep OS in its own partition and keep the data files in another.
- You did not mention your Operating System. Make sure that your hardware meets the minimum OS system requirements.
@arjun-srivastav-Ble7PW • Oct 18, 2012
thank you -
thanks guys...😀
