How can I improve this code?
<b>code.py</b>
# A simple notebook application
import code_util as util
# defining a class
available_bookclasses = ('private', 'public', 'none')
class notebook:
# Varibles
book_name = ''
book_class = available_bookclasses[2]
item_name = ''
book_code = util.assign_code()
items_list = []
def __init__(self,name):
self.book_name = name
def _get(self,items):
if ((items < 0)):
print ("Invalid number of items..")
for i in range(items):
self.item_name = input("Enter item name: ")
self.items_list.append(self.item_name)
def count(self):
return (len(self.items_list))
def show_summary(self):
print ("Name of the stored book: %s\n" %(self.book_name))
print ("Secret code: %d\n" %(self.book_code))
print ("Printing items in the list...\n")
for i in range(self.count()):
print ("Items [%d]: %s\n" %(i,self.items_list[i]))
def create_copy_code(self):
return (self.book_code)
def __str__(self):
self.show_summary()
def change_class(self,class_name):
if class_name in available_bookclasses:
self.book_class = class_name
else:
util.error("Search failed: %s\n" % class_name)
code_util.py
# Utility Module
import random
import math
import sys
def error(*arg):
print ("Number of errors: %d\n" % len(arg))
for i in range(len(arg)):
print ("Error [%d]: %s\n" %(i,arg[i]),file = sys.stderr)
def assign_code():
() -> int
return the assigned number
>> assign_code()
10q0
>> assign_code()
547a4
# Varibles used in the assign_code()
value_to_use = [22,3,4,2,3,2,3,3,111,2232,44,323,90909,9,23]
number_to_use = [1,2,3,42,5,3,5,3,4,3,32,4,2,2,4]
assigned_code = '' # The end result
big_number = number_to_use[0] # let big_number be the largest number
big_value = value_to_use[0] # let big_value be the largest number
try:
for n in range(len(number_to_use)):
if (number_to_use[n] > big_number):
big_number = number_to_use[n]
n_use = random.randint(0,big_number)
n_use*=100
for v in range(len(value_to_use)):
if (number_to_use[v] > big_value):
big_value = value_to_use[v] # Largest value
# Making it more harder
v_use = random.randint(0,big_value)
v_use*=100
except ValueError:
error("Code Generation")
if (n_use > v_use):
v_use+=n_use
assigned_code = int(math.sqrt(random.randint(n_use,v_use))) # Creating code...
assigned_code = math.sqrt(assigned_code * 100 * 100)
return (int(assigned_code))
