hey guys, another question in for ya
OrAnGeWorX
@orangeworx-oOtGlX • Oct 26, 2024
I got some code i'm trying to write to determine some information (comparisons and counters) on user input
The user enters an integer (total number of animals to be entered in tables)
the user is then asked to input info on the first animal (sexe, a char,age, an int, poids, a float and taille a float as well
after the final animal information is entered, the program will then print out information based on the following conditions:
- element coordinates for males over 30 long (taille) (needs a little work... was only counting them)
- count and print out the number females under 1kg (poids)
- to calculate and print out average age of males and females (stuck there, just won't work properly)
- to calculate and print the shortest and tallest animal heights (needs a sorting algorithm.)
so the code without further adue.
#include <stdio.h>
#include <stdlib.h>
#include <ctype.h>
#define HAUTEUR 30.0
#define POIDS 1.0
int main()
    // initialisation des variables
    int nbrAnimaux=0;                            // Valeur que specifie l'usager pour creer les tableaux
    int nbrMale=0;                            // compteur animaux males
    int nbrFemelle=0;                            // compteur des femelles
    int nbrMaleG=0;                            // compteur des animaux > 30cm de longueur
    int nbrFemelleL=0;                        // compteur des femelles < 1kg
    int i, j;                                    // compteur boucle
    int ageM=0;
    int    ageMoyenM=0;                            // age total et moyen des males
    int ageF=0;
    int ageMoyenF=0;                            // age total et moyen des femelles
    int plusCourte=0;
    int plusLongue=0;
    char condition;                           // Oui ou Non
    float taille[nbrAnimaux], poids[nbrAnimaux];
    int age[nbrAnimaux];
    char sexe[nbrAnimaux];
    nbrMale = 0;
    nbrFemelle = 0;
    nbrMaleG = 0;
    nbrFemelleL = 0;
    // Boucle do ... while, pour ne pas devoir repartir le programme pour chaque calcul
    do
    nbrFemelle=0;
    nbrMale=0;
    // Saisi et lecture des donnees
    printf("SVP entrez le nombre d'animaux pour vos calculs:\n");
    scanf("%d", &nbrAnimaux);
    // printf("Maintenant, SVP entrez les details comme ceci, \nSexe (M/F), Age, Poids et Longueur\n");
 //   for (i=0; i < nbrAnimaux; i++)  {
   //      printf("tableau sexe: %c\n", &sexe[i]);}
    for (i = 0; i < nbrAnimaux; i++)
        fflush(stdin);
        printf("Animal %d\n", i+1);
        printf("entrez sexe (M/F)\n");
        scanf("%c", &sexe[i]);
        printf("entrez l age en jours\n");
        scanf("%d", &age[i]);
        printf("entrez le poids en kg\n");
        scanf("%f", &poids[i]);
        printf("entrez la longueur en cm\n");
        scanf("%f", &taille[i]);
        for (j = 0; j < nbrAnimaux; j++)
            if (toupper(sexe[j]) == 'M' && taille[j] > HAUTEUR)  // Compter les males > 30cm de long
            nbrMaleG++;
            if (toupper(sexe[j]) == 'F' && poids[j] < POIDS)    // Compter les femelles < 1k de poids
            nbrFemelleL++;
            if (sexe[j] == 'M')                                    // ajouter l'age des males et femelles
            ageM += age[j];
            else
            ageF += age[j];
            if (toupper(sexe[j]) == 'M')                // Compter les males et femelles
            nbrMale++;
            else
            nbrFemelle++;
    ageMoyenM == ageM / nbrMale;
    ageMoyenF == ageF / nbrFemelle;
    printf("Non demande\n");
    printf("===========\n");
    printf("Nombre de males: %d\n", nbrMale);
    printf("Nombre de femelles: %d\n", nbrFemelle);
    printf("Demande\n");
     printf("=======\n");
    printf("Nombre de males mesurant plus de 30cm: %d\n", nbrMaleG);
    printf("Nombre de femelles pesant moins de 1kg: %d\n", nbrFemelleL);
    printf("Age moyen des males: %d et l\'age moyen des femelles: %d", ageMoyenM, ageMoyenF);
     // debug
  //  for (i = 0; 1<nbrAnimaux; i++)
  //   printf ("a la case %d, le sexe est %c, l'age est %d, le poids est %f et la longueur est %f", i, sexe[i], age[i], poids[i], taille[i]);
     // end debug
     // Condition requise pour repartir du début
     printf ("\nVoulez vous faire un autre calcul, (o/n)?");
     fflush (stdin);                        // Fonction pour vider stdin
     condition = toupper(getchar());        // Capitaliser la letter et soumettre à condition
     } while ( condition == 'O');                // Repartir du début si O
     // fin du do while restart
  • OrAnGeWorX
    @orangeworx-oOtGlX • Nov 17, 2008
    Been trying to tweak the code, still to no avail (maybe a little better than before)
    i tried to print out the values of the tables before running the program and the int/char tables are displaying weird stuff
    here's some info
    4
    tableau sexe: ┘
    tableau age: 37813980
    tableau poids: 0.000000
    tableau sexe: ┌
    tableau age: 37813984
    tableau sexe: █
    tableau age: 37813988
    tableau sexe: ▄
    tableau age: 37813992
    my tableau sexe is a char table... it's displaying weird caracters
    and the age table should be 0'd out as well right? like the age and poids tables.
  • OrAnGeWorX
    @orangeworx-oOtGlX • Nov 18, 2008
    Any1 got some ideas ? pretty please ?
  • OrAnGeWorX
    new code... works a whole lot better, just a couple glitches
    /* Ce programme saisi des données sur des animaux etudiés par une biologiste:
          - 1ere ligne, leur nombre, pour créer les tableaux qui contiendront
            les infos
          - 2eme ligne et + (jusqu'au nombre saisi à la première ligne), leur sexe
                 (M ou F, char), leur age (en jours, int), leur poids (en kg, réel)
                 et leur taille (en cm, réel)
       et affiche des résultats selon ces critères:
          - les coordonnées des males de plus de 30cm
          - le nombre de femelles qui pèsent moins de 1.0 kg
          - l'age moyen des femelles et celui des males
          - la longueur minimale et maximale des animaux */
    #include <stdio.h>
    #include <stdlib.h>
    #include <ctype.h>
    #define POIDS 1.0
    int main()
        //int coordMG=0;                            // compteur des animaux > 30cm de longueur
        int ageTotalM=0;                       // age total et moyen des males
        int ageTotalF=0;                       // age total et moyen des femelles
        float taillePlusCourte=5000;
        float taillePlusGrande=0;
        do
                age[i] == 0;
            for (i = 1; i <= nbrAnimaux; i++)
            printf("Animal %d\n", i);
            fflush(stdin);
            fflush(stdin);
            fflush(stdin);
            fflush(stdin);
                    // debug
            for (i = 1; i <=nbrAnimaux; i++)
                printf("sexe: %c ", sexe[i]);
                printf("age: %d", age[i]);
                printf("poids: %f", poids[i]);
                printf("taille: %f\n", taille[i]);
            // end debug
            for (j = 1; j <= nbrAnimaux; j++)
                   nbrMale++;
                   ageTotalM += age[j];
                else
                   nbrFemelle++;
                   ageTotalF += age[j];
                    nbrFemelleL++;
                    printf ("Coordonnes du repere Male > 30cm: %d\n", j);
                if (taille[j] < taillePlusCourte)
                    taillePlusCourte = taille[j];
                if (taille [j] > taillePlusGrande)
                    taillePlusGrande = taille[j];
        // printf("Age moyen des mal%& %d% et l\'age moyen des femelles: %d\n", ageTotalM/nbrMale, ageTotalF/nbrFemelle);
        printf("Taille plus grande: %6.2f et taille plus courte: %6.2f\n", taillePlusGrande, taillePlusCourte);
        // debug
         // end debug
    and the results after running:
    3
    Animal 1
    entrez sexe (M/F)
    M
    12
    3
    34
    Animal 2
    entrez sexe (M/F)
    M
    123
    1
    3
    Animal 3
    entrez sexe (M/F)
    F
    134
    .14
    4
    // debug section
    sexe: M age: 1107820544poids: 34.000000taille: 34.000000
    sexe: M age: 1077936128poids: 3.000000taille: 3.000000
    sexe: F age: 1082130432poids: 4.000000taille: 4.000000
    // end of debug section
    Coordonnes du repere Male > 30cm: 1
    Nombre de males: 2
    Nombre de femelles: 1
    Nombre de femelles pesant moins de 1kg: 0
    Taille plus grande: 34.00 et taille plus courte: 3.00
    what works and what doesn't:
    Works
    - program picks up proper number of males and females
    - program gives shortest and longest heights
    - program gives the coordinates of the males > 1 (just not sure if that's what the teacher meant)
    Doesn't work
    - program will not give good reading for females under 1kg ( the condition is probably the problem (or maybe my for loop with the conditions in it)
    - program doesn't/can't give out proper readings for average male and female ages.
    - also i have issues flushing the memory after the user selects "o" to restart the program... it seems to keep all the data from the previous run.
    thanks again
