  • slashfear
    @slashfear-tSWzpz • Apr 4, 2011
    Hi Jiyan,
    The most easiest way I would suggest is using the resources you already have ๐Ÿ˜‰ so use google translator. All you have to do is write a program to connect to google translator and input the characters you wanna translate and fetch the result set and display it to user!! simple....
    P.S: May be I will write a small perl script and show you how to do it.. if you want!! ๐Ÿ˜‰-Arvind
