@differential-0aMwAJ • Feb 10, 2009
Hi and welcome to the forum! This is really an amazing idea!
Could you please tell us how you detect obstacles? Can we modify that logic for detecting pits and digs as well?
This links me to something called as SONAR that I learned in school. SONAR system is used to measure the depth of sea and is used on ships. -
@gohm-F3UUpP • Feb 11, 2009
Yes, great subject! a little more background on the project would help us to give suggestions on your questions. Sounds to me like you want a range finding device with a wide beam to compare for a measured difference (between level ground and a hole- this would eliminate a false alarm while stick is raised in walking), if finding one, using a signal or vibration as a caution alert?
@instinctz-bEC70o • Feb 11, 2009
With out knowing much of the details of the project.. my mind wonders. How ever I can think of one decent idea to run with for detecting such "pits". Most sensors have a large operating range (width of dectection) so I dont think sensors like sonar, and other normal means would do well.
But possibly something like the "Texas Advanced Optical Systems (TAOS) TSL230R" which is a light to frequency converter could work. Basicly your going to average the reflectivity and when it jumps to dark it could give an alarm, indicating a pit. -
annan OP
@annan-YdDwQV • Feb 12, 2009
Thanks for all you people's positive responses. And sorry for not showing much details. We have just started it. And what we now think is using an ultrasonic transmitter and receiver pair for detecting objects infront and use an alert system such as ear phone. But we were confused about pit detection with minimum error. Now what we think is to use one more sensor at bottom of a projection and use a memory element and a comparator which will compare the previous reflection with the present reflection and when there is a change more than a threshold value (which will be set by PIC or microcontrol ) the alert system will be activated. But this won't be the circuit with minimum error and we wish it to be cheaper too.And there is possibility for false alarm while raising the stick though this can be eliminated by using two sensors and comparing....
@teena-angale-CQXBfJ • Mar 7, 2009
hey even im doin a mini proj on the electronic stick.pl can u send ne the code on <removed>. it would be of great help...thanks!
@thebigk • Mar 7, 2009
teena angalehey even im doin a mini proj on the electronic stick.pl can u send ne the code on <removed>. it would be of great help...thanks!
We don't help with homework.
@bee-bharath-AF7CqY • Aug 15, 2011
Use ultrasonic sensors
@myjuliet-KsL0Dq • Aug 17, 2011
We confused the pit with minimal error detection. Now we think that is the bottom of the projector and use of more sensors, memory elements, which will now reflect a more reflective and more the former..
_______________________
<link removed>#-Link-Snipped-# -
@enggricha-mOff5Q • Aug 17, 2011
Ultrasonics is the way to go about this...you might want to look at SRF02 or similar transducers. Problem is they arent available in India. However I saw these at Ensemble Technologies they have these for their project requirements. Its possible that they might be into selling these too.
@chauhanpratyush-vTm6Q0 • Aug 20, 2011
how can ultrasonics be used here????????...would someone explain......
