  • Help Required on PHP
    techbkr3
    techbkr3
    @techbkr3-gsED1X
    Updated: Oct 25, 2024
    Views: 1.4K
    Excuse me CEans,
    I am trying to retrieve the data from MySQL Database using WHERE function, but here i want to check WHERE='123' as input. To say clearly (i.e) WHERE=%INPUT%
    thereby i can enter some input on dialog box and by clicking a button, the input given is used to retrieve the data via WHERE function.
    Any Examples ??
    or should i go ahead with JS ?
  • [Prototype]
    MemberSep 1, 2012
    You're facing problem in query or taking input?
    In php, you can use the GET & POST request to transfer the input.
  • techbkr3
    MemberSep 1, 2012
    Thanks for your reply !
    Let me check about that and get back to you soon 😀
    P.S: Actually, i am not facing any problems here. I am seeking for the technique usage of WHERE function(MySQL) using user-defined input.
  • Prasad Ajinkya
    MemberSep 2, 2012
    Tech, I could type this out in this forum, but this link on php.net explains it with sample code - <a href="https://www.php.net/manual/en/mysql.examples-basic.php" target="_blank" rel="nofollow noopener noreferrer">PHP: MySQL extension overview example - Manual</a>
    Your WHERE clause is part of your mysql query. Its not part of PHP
    HTH
  • sulochana anand
    MemberSep 3, 2012
    [Prototype]
    hi i m
    Beginner for php.i installed it on my system.typed code in notepad.after that wat should i do to run php.
  • Manish Goyal
    MemberSep 3, 2012
    sulochana anand
    hi i m
    You can Install some open source servers like wampp or xampp in your system, then put your php inside htdocs folder , after that you can run your file using your browser
    by typing
  • sulochana anand
    MemberSep 3, 2012
    is htdocs predefined folder
  • Manish Goyal
    MemberSep 3, 2012
    Yes when you will install these server, htdocs will be inside it
    You just need to place your files there
  • sulochana anand
    MemberSep 3, 2012
    ok thanks i will try to do so.
  • Harish Kotra
    MemberSep 4, 2012
    Okay, I guess I will get you the working script completely here in this reply. As you said you need to enter a text and clicking button should retrieve it from the database.
    - Create a form and remember POST is an ideal method in the forms usually.
    <form action="search.php" method="POST">
    <input type="text" name="ele" />
    <input type="Submit" name="submit" value="Submit" />
    </form>
    - Now the PHP code to connect to the data base first and then search for what you actually need.
    <?php
    $dbuser = "user_access"; //username you created
    $dbpass = "Anonym0us"; //password for the user
    //variable to connect to the database
    $con = mysql_connect("localhost","user_access","Anonym0us");
    if (!$con)
    die('Could not connect: ' . mysql_error());
    //Connect to the database you created.
    mysql_select_db("my_db", $con);
    if($_POST['search'] == 'Search')
    //foreach loop I am using here is just for a bit of security. You can do it directly also.
    foreach($_POST as $key => $value) {
    $data[$key] = filter($value);
    $searchele = $data['ele'];
    //tablename to be replaced with your table.
    //rowname should be replaced with the row you want to search in.
    //Coded by me Harish Kotra
    $search = mysql_query("select * from tablename where rowname like '%$searchele%'");
    while ($row = mysql_fetch_array($search)){
    echo $row['rowname'];
