Help regarding Bluetooth transmission
arpitddn
arpitddn
@arpitddn-9mU3gF Oct 21, 2024
I am newbie in electronics and i don't know how to start.
I want to connect memory card to computer through Bluetooth, but i dont have a clue where to start from.
Please help.
  • pratap singh, upendra
    @pratap-singh-6xlmve Jun 25, 2012
    you cannot connect a memory card to a computer via bluetooth. Memory card doesn't support bluetooth.
    I think you want to connect your cellphone(containing memory card) to a computer in order to transfer data.
    If this is the case, see your manual that comes with the cellphone, it will have all the instructions that you need in order to use bluetooth
  • arpitddn
    arpitddn
    @arpitddn-9mU3gF Jun 28, 2012
    Proffy,
    Thank you Sir for your reply. Is there a way, we can use pen drive for Data Transmission?
    I am new to this , and what i was able to see is, usb pendrive and blutooth module, both has 4 pins.
    can't we use pendrive then?
  • Reya
    Reya
    @reya-SMihdC Jun 28, 2012
    What for Pendrive is used if not for data transmission?
  • arpitddn
    arpitddn
    I mean to say, through bluetooth
    Harshad Italiya
    @harshad-ukH5ww Jun 29, 2012
    arpitddn
    Please help.
    You can Connect your Memory card with Microcontroller Then Read File system from Memory Card and after that You interface Bluetooth with same MCU and you can connect with PC after that. So It is possible.
