Help php
sheltabrisk
sheltabrisk
@sheltabrisk-pgdruM Oct 25, 2024
hello friends
i studing php but could not know the application .any body tell how to use php in web programming.i want decide devlope the one project tell some project headings
  • davidc2p
    davidc2p
    @davidc2p-K2wdIC Feb 16, 2007
    wow, this is a vaste question! could you be just a bit more specific?
    @thebigk Feb 16, 2007
    I agree with David. sheltabrisk, it would help if you elaborate on what you want to do.
    Is it that you only want to know about the applications of php?
    -The Big K-
  • simplycoder
    simplycoder
    @simplycoder-NsBEdD Aug 19, 2011
    @sheltabrisk: Since you are starting up with php, you should know how to declare variables and math operations.
    you can then be in a position to design a web-page which has some php-code in it.
    Learn how to take input from the textfields and how to use submit button.
    The basic assignment is you can make a php calculator. If you are interested, you can also try your hands on sudoku solver, sudoku generation is a bit difficult as compared to solver.
    Later on learn some MySQL and then how to link web-page to MySQL database or for that matter any database.
    simpler assignment might be creating a registration/login form, this will teach you basically how to insert and retrive the data from database.
    Larger assignment would be.. Build a complete website using php-mysql!
    Let me know if you want some particular help.I shall try to help you out.
    -Thank you.
