help needed in creating a database in MS Access
Reya
@reya-SMihdC โ€ข Oct 16, 2024
hi friends i got a prob in creating a database..can some one help me in solving?
i created a database in ms access.I went to
control panel-administrative tools-data sources(ODBC) to create a new data source..
There i could see the name of the database with the driver sql server which i created in ms access..
why?
i selected ms access database under the label name and clicked add button create new data source dialog box appears..In that box select a driver for which you want to set up a data source..i can see only sql server under the label name..i was not able to see Ms access driver..if i click finish another dialog box create a data source to sql server..if i give the name and click finish odbc sql server is created.How to create the data source in ms access? reply me soon.
  • Reya
    @reya-SMihdC • Sep 28, 2010
    can anyone clear my doubt??
  • Manish Goyal
    @manish-r2Hoep • Sep 28, 2010
    which language are you using for your front end?
  • Reya
    using java in front end
