Help me with this C problem
pavlejovanov
@pavlejovanov-7GbyX5 • Oct 25, 2024
Please help me somebody how to put integer into file. In variable 'mnozenje' I have the right numbers but in the file 'Weights.txt' I have this ĂĂĂȂāāĀ.With printf("%d",mnozenje); in the console the numbers are correct. I will copy all my code:
#include "stdafx.h"
#include "stdio.h"
#include "stdlib.h"
int _tmain(int argc, _TCHAR* argv[])
        FILE *train, *weights,*test ;
        char ch ;
        train = fopen ( "Train.txt", "r" ) ;
        if ( train == NULL )
               puts ( "Cannot open source file" ) ;
               return 0 ;
        test = fopen ( "Test.txt", "r" ) ;
        if ( test == NULL )
               return 0 ;
        weights = fopen ( "Weights.txt", "w" ) ;
        if ( weights == NULL )
               puts ( "Cannot open target file" ) ;
               fclose ( weights ) ;
               return 0 ;
        int i=0,vektori=0,nevroni=0;
        while ( i<=3 )
                i++;
                ch = fgetc ( train ) ;
                if ( ch == EOF )
                       break ;
                else
                    if(i==1)
                        vektori=atoi(&ch);
                    if(i==3)
                        nevroni=atoi(&ch);
        int x=1,y=1,a[100][100],w[100][100];
        char c;
        while(1)
            if ( ch == EOF )
                break ;
                if(ch!=10)
                    a[x][y]=atoi(&ch);
                    if(y==nevroni)
                        x++;
                        y=0;
                    y++;
        int pomos=1,mnozenje=0,s;
        for(int k=1;k<=nevroni;k++)
            for(int l=1;l<=nevroni;l++)
                if(k!=l)
                    while(pomos<=vektori)
                        mnozenje+=a[pomos][k]*a[pomos][l];
                        pomos++;
                    w[k][l]=mnozenje;
                    c=(char)mnozenje;
________________________________________________________________
                    fputc ( mnozenje, weights )  ;//here is the problem
                    mnozenje=0;
                    pomos=1;
        fclose (train) ;
        fclose (weights);
        fclose (test);
                    scanf("%d",s);
    return 0;
  • sumitjami
    @sumitjami-UHV2GH • Jan 8, 2009
    What I think is that u are trying to directly write an integer value in the form of char to a file now suppose the int variable contains a value greater than 256 than in what kind of char would that int value be converted into..............so to directly convert the int value u should use the function "itoa()" to convert the value from in to a String and then insert that string into the file and your problem will be resolved TRY THIS OUT 😁
  • pavlejovanov
    @pavlejovanov-7GbyX5 • Jan 8, 2009
    First thanks for helping me. I try this but I don't know how to use the function itoa(). I try this:
    char buffer[50],c;
    c=itoa( mnozenje, buffer,10);
    fputc ( c, weights ) ;
    I google this but it doesn't works. I don't know what is buffer and how works itoa() function??? If you have ever use, or somebody else, please try something and write me how I can solve my problem.😕
    I find an example where variable c is string, but in C language I can't use the type string.
  • pavlejovanov
    OK I solve this problem... If somebody have problem like this the solution is:
    char buffer[50],*c;
    fputs ( c, weights ) ;
    So the problem was I must use fputs not fputc and c must be a pointer.
  • sumitjami
    @sumitjami-UHV2GH • Jan 14, 2009
    did u understand what u did............actually in the function itoa() the number which was passed in "mnozenje" was converted to a string this function returned a pointer to that string and later that string was written to the designated file using the function fputc()
  • aaseem.sufi
    @aaseemsufi-rOjTss • Jan 23, 2009
    try fprintf(weights,"%d",mnozenje);
    pavlejovanovPlease help me somebody how to put integer into file. In variable 'mnozenje' I have the right numbers but in the file 'Weights.txt' I have this ĂĂĂȂāāĀ.With printf("%d",mnozenje); in the console the numbers are correct. I will copy all my code:
    #include "stdafx.h"
    #include "stdio.h"
    #include "stdlib.h"
            char ch ;
                   return 0 ;
            if ( test == NULL )
                   return 0 ;
                   return 0 ;
            while ( i<=3 )
                    i++;
                    if ( ch == EOF )
                           break ;
                    else
                        if(i==1)
                            vektori=atoi(&ch);
                        if(i==3)
                            nevroni=atoi(&ch);
            char c;
            while(1)
                if ( ch == EOF )
                    break ;
                    if(ch!=10)
                        a[x][y]=atoi(&ch);
                        if(y==nevroni)
                            x++;
                            y=0;
                        y++;
                    if(k!=l)
                            pomos++;
                        w[k][l]=mnozenje;
                        c=(char)mnozenje;
                        mnozenje=0;
                        pomos=1;
            fclose (train) ;
            fclose (weights);
            fclose (test);
                        scanf("%d",s);
        return 0;
