help me to solve it
TaraJava
@tarajava-fqIQFu โ€ข Oct 22, 2024
import java.awt.Graphics;
import java.applet.Applet;
import java.awt.Color;
public class Main extends Applet implements Runnable
Thread t;
int x=500;
int y=745;
@Override
public void init()
setBackground(Color.black);
@Override
public void start()
if(t==null)
t=new Thread(this);
t.start();
@Override
public void stop()
if(t!=null)
t.stop();
public void run()
while(true)
if(y<250) //
y=y+5; //
else
y=y-5;
repaint();
try
Thread.sleep(40);
catch(InterruptedException ex)
@Override
public void paint(Graphics g)
g.setColor(Color.red);
g.fillOval(x,y,50,50);
i have a problem in the commented line wham am i trying to do is first display the circle at the location and make it move upwards by reducing it by five and that is working fine...so than what do i want is after reaching certain position am making 250 i want the ball to return back so i just made it opposite by adding 5 now why is the logic not working ......please explain me the logic.....every part of the code is working fine beside that thanks
  • sookie
    @sookie-T06sFW • Jul 8, 2012
    Hi #-Link-Snipped-#,
    Please check the below code if this is what you were expecting for the desired o/p
    Thread t;
    int x=500;
    int y=745;
    boolean goup=true;
    int count=0;
    @Override
    public void init()
    @Override
    public void start()
    if(t==null)
    t=new Thread(this);
    t.start();
    @Override
    public void stop()
    if(t!=null)
    t.stop();
    public void run()
    while(true)
        if(goup){
        y=y-5;
        }else{
      y=y+5;
        /* It initializes the y to 250 and circle moves in downward direction */
        if(y==250){
      System.out.println("Value reached 250");
      y=250;
      goup=false;
        /* It initializes the y to 745 and circle moves in upward direction */
        if(y==745){
      System.out.println("Value reached 745");
      y=745;
      goup=true;
    repaint();
    try
    Thread.sleep(40);
    @Override
    The problem that I found in your logic was you were updating the 'y' value in while loop and at the same time it is used in "paint" . Moreover when your value of 'y' reaches 245 (<250) it goes in "if" block and again changes the value to 250 and again next time it comes in else loop and it decrements the value to 245. In this way your program keeps on looping between value 245 and 250.
    In order to avoid this I have controlled upward and downward journey using a boolean variable "goup" default is true means circle will move in "upward" direction" and when y reaches to 250, its value is set as "false" so that circle moves in "downward direction from 250 on wards.
  • TaraJava
    @tarajava-fqIQFu • Jul 9, 2012
    ok thank you for the reply but i found a problem in running your program its having some bugs ,any way i got some ideas from your program .....I want to ask a next question how would i make a multiple balls moving up down in the same program ...waiting for your reply
  • sookie
    @sookie-T06sFW • Jul 9, 2012
    TaraJavaok thank you for the reply but i found a problem in running your program its having some bugs ,any way i got some ideas from your program .....I want to ask a next question how would i make a multiple balls moving up down in the same program ...waiting for your reply
    1. Can you Please post the bugs found in my program. It is working fine at my end. I have just changed while loop and added two variables('count' can be removed..๐Ÿ˜ณ) in same program of yours.
    2. Program for multiple balls -> First try writing it yourself.
  • TaraJava
    am confused why you been doing this
    if(y==250){
    y=250;
    goup=false;
    why are you assigning 250 to y the value of y is 250 only.when i run ur program first the ball
    moves upward but reaching the point it cant come back..
    2.making the multiple balls let me not be lazy yea am trying ...thanks anyway
