@abhirv-onWvxk • Jul 2, 2011
if its an LTI system then even the output will be shifted by the same amount as input....so o/p willbe r(t-2)..!!
Bishshoy Das OP
@bishshoy-das-Q53VY6 • Jul 3, 2011
abhirvif its an LTI system then even the output will be shifted by the same amount as input....so o/p willbe r(t-2)..!!
yes but you have assumed time invariance, which is not mentioned in the problem ! linear systems need not be time invariant !
also if i suppose the response is r(t-2) then the waveform changes. the waveform r(t) and r(t-2) are not same.
3exp(-4*(t-2)) = r(t)*exp(8) !
anybody else wanna help me.
please post a mathematical solution than a logical analysis. -
Bishshoy Das OP
@bishshoy-das-Q53VY6 • Jul 4, 2011
anybody wanna give the sum a try
