@zaki-whiz03-QzR6CP • Jan 19, 2012
i would suggest you to download google sketchUp which is very user friendly. You can create 3D models if you have the basic knowledge of auto cad..
@venkatkingv-rzuAXN • Jan 19, 2012
vipandeepHello guys!
I am very new to CAD and I am looking to create a 3D model of the attached part. Its pretty simple but I just don't know how to create that slanting surface at the top. I am not even concerned about dimensions. Thanks!Sir,
u can learn from cad helping files which explain briefly how work in cad...!
just get it from help menu.. -
@amol-sidankar-kXMHRv • Jan 23, 2012
i want to install catia how can i install crack file?
@naveen-rathee-madwQq • Jan 25, 2012
Amol Sidankari want to install catia how can i install crack file?
you can not ask such questions on this form.Take care in future.
@thebigk • Jan 25, 2012
We don't encourage piracy. Ask on some other forum.
@ishan-nohePN • Jan 25, 2012
May be you should try solidworks. You can easily download it by searching on Google. It is free as far as I know. 😀
@ce-designer-BWq0yl • Jan 27, 2012
Solid Works for free????????? If you find this please post the link here hehehehehe, but i highly doubt that you can dload it for free. Google Sketchup is great and i know its free. Use that!
@ishan-nohePN • Jan 27, 2012
CE DesignerSolid Works for free????????? If you find this please post the link here hehehehehe, but i highly doubt that you can dload it for free. Google Sketchup is great and i know its free. Use that!
Some time back, Ramani sir had made a small model of solar water heater and we all wanted to view it in our computers. He suggested that we download it. I have Unfortunately I never used it again. Here is the link. Hope it works-<a href="https://www.solidworks.com/sw/support/downloads.htm" target="_blank" rel="nofollow noopener noreferrer">Downloads | Support | SOLIDWORKS</a>
ReyaI think, issue meant the trial version of solid works 😛
Yes I think it is trial version.
@ammar-aziz-7MLZYl • Jan 31, 2012
if you are working in auto cad
then you can draw a slanted surface by establishing a new UCS -
@viky1147-Ru5Vmg • Feb 6, 2012
Ya for 3D modeling its better you try PRO/E or Solid works 😀
@ramani-VR4O43 • Feb 6, 2012
@alex-ee-DTGprl • Feb 7, 2012
try #-Link-Snipped-#
go to click on trial version . there are autocad for student and also for trying. Hope you can download from there. -
@ashish-BOJVMw • Feb 8, 2012
any1 want to download Auto-Cad or related s/w. go to
<a href="https://www.autodesk.com" target="_blank" rel="nofollow noopener noreferrer">Autodesk | 3D Design, Engineering & Construction Software</a>
1. register yourself
den you can download available s/w free of cost and that too original. -
my friend are you asking about how to chamfer the surface in 3d cad s/w?
@zaveri-5TD6Sk • Mar 27, 2012
what about pro-e ? how much does the software cost in the market ?
I am very new to CAD and I am looking to create a 3D model of the attached part. Its pretty simple but I just don't know how to create that slanting surface at the top. I am not even concerned about dimensions. Thanks!hey that is damn easy !
i know creating this model in pro-e
first sketch a circle of the given diameter and then extrude it to form the cylinder of the required length, without considering the chamfered top slant portion.
then create a datum plane parallel to the cylindrical face of the object. sketch the profile of the portion of the material that will be removed after chamfering.
next press "extrude" and then the "remove material" command and finally "Done" -
@reya-SMihdC • May 16, 2023
