help - gas processing - final project
coelhothiago
@coelhothiago-x1rfvN โ€ข Oct 21, 2024
I am a chemical engineering student and my final project is about a processing gas plant. It is a DDP (Dew Point Plant).
In the end of the process, there is a stabilization tower that separates two fractions, one light having C1 and C2 and other heavy with C3, C4, C5+.
The idea is to separate the C3 from the heavy stream to reuse in the refrigeration system (simple refrigeration by propane) of the plant. Today the C3 for refill the refrigeration system is bought, so we want make itself sustainable in refrigerant fluid with this adaptation.
Which would be a good layout and equipments to do that? Does someone have any tip?
Thank You
Thiago
