Hello guys here comes a real problem that i face.
Keerthivasan Ravisankar
@keerthivasan-hrKQir โ€ข Oct 21, 2024
[HASHTAG]#windows[/HASHTAG] I'm Using windows 7 Home Premium 64bit original Operating system, Sony Make.
The problem is,
In Programs and Features for every program installed in it will have a uninstall option.
But for past few weeks i can't able to find uninstall option for few programs.
"Eg.
I'm Using BSNL data card(application named Capitel connect) , the uninstallation file for that is not visible in 'Uninstall or change a program' window.
Nearly 2 to 3 programs have these type of problem."
need help & a valid answer.
I taught of deleting the program from '' C '' Drive. but if i delete like that, the registry file for that particular program will get struck there itself and make my system overload/hang sometimes.
have any one faced these type of problem.?
    @anoop-kumar-GDGRCn • Jul 22, 2014
    Seems your OS has corrupted. Possible that you don't have admin rights now to uninstall a program.
    Do a <a href="https://sourceforge.net/projects/hjt/" target="_blank" rel="nofollow noopener noreferrer">HiJackThis download | SourceForge.net</a>run and fix all the things except OS related thing or fix everything, it will fix your registry. There might be chances that autorun program may not work but this will pause all the virus execution.
  • Keerthivasan Ravisankar
    @keerthivasan-hrKQir • Jul 22, 2014
    ok. What will this software do, scans registry?
    Need Help to fix this issue
    Yes, it will fix the registry.
  • HRG
    HRG
    @hrg-sm4qy1 • Jul 22, 2014
    you can use tuneup utilities -> tuneup uninstall manager to uninstall stuffs that dont appear in windows control panel .
  • Manish Goyal
    @manish-r2Hoep • Jul 23, 2014
    Most of the programs with separate uninstall.exe you can use it
    it should be available under program files -> program name say x with name uninstall.ext
    @keerthivasan-hrKQir • Jul 23, 2014
    HRGyou can use tuneup utilities -> tuneup uninstall manager to uninstall stuffs that dont appear in windows control panel .
    Thank you for replying
    i tried Tuneup Utility too but same not displaying.
    Manish GoyalMost of the programs with separate uninstall.exe you can use it
    Thank you for reply.
    Any how the link of that will appear in Programs and Features window. but its not there in the folder that you are denoting. For your info i have checked already in that program folders!.
    Anoop KumarYes, it will fix the registry.
    is there any instruction how to use <a href="https://sourceforge.net/projects/hjt/" target="_blank" rel="nofollow noopener noreferrer">HiJackThis download | SourceForge.net</a>
  • HRG
    HRG
    @hrg-sm4qy1 • Jul 23, 2014
    Then try the windows Installer Cleaup utility tool .#-Link-Snipped-# . I should work !
    @anoop-kumar-GDGRCn • Jul 23, 2014
    Keerthivasan Ris there any instruction how to use <a href="https://sourceforge.net/projects/hjt/" target="_blank" rel="nofollow noopener noreferrer">HiJackThis download | SourceForge.net</a>
    It's fairly simple.. execute hiJackthis, analyse and fix selected.
    That's it.
    @keerthivasan-hrKQir • Jul 27, 2014
    [SOLUTION]
    At-last achieved.
    Here is the solution for this problem.
    Re-install the same program again, and there comes the uninstall option.
    Thank you for replying...
    Next time some other problem may arise....So be ready for that.๐Ÿ‘
