    @thebigk • Jan 17, 2013
    May I request all the mechanical engineering folks to look into this? #-Link-Snipped-# , maybe you could offer some help?
  • ISHAN TOPRE
    @ishan-nohePN • Jan 17, 2013
    Heat treatment is application specific. For machining it, you will not want to harden it (no quenching). May be you should specify what you are trying to do. Do you want to make die casting tool?
    Refer manual for the material.
    Also this may help-https://#-Link-Snipped-#
  • CE Designer
    @ce-designer-BWq0yl • Jan 17, 2013
    The heat treatment process known as Annealing can be used on steels to reduce strength or hardness thus making the steel easier to form and machine.
    @ramani-VR4O43 • Jan 17, 2013
    <a href="https://www.matweb.com/search/datasheettext.aspx?matguid=f3a3e3b55073438aae3206a3a4070f7d" target="_blank" rel="nofollow noopener noreferrer">International Mold Steel DH2F Pre-Hardened H13-Type Mold Steel</a>
    If the steel is pre heat treated, post machining operations, cost and time can be reduced. It is not clear if your question refers to this option of pre-hardened free machining steel.
