HEAT RECOVERY STEAM GENERATOR
Velshankar MJ
@velshankar-sD1Glu • Oct 23, 2024
A common application for an HRSG is in a combined-cycle power station, where hot exhaust from a gas turbine is fed to an HRSG to generate steam which in turn drives a steam turbine. This combination produces electricity more efficiently than either the gas turbine or steam turbine alone. Another application for an HRSG is in diesel engine combined cycle power plants, where hot exhaust from a diesel engine, as primary source of energy, is fed to an HRSG to generate steam which in turn drives a steam turbine. The HRSG is also an important component in cogeneration plants. Cogeneration plants typically have a higher overall efficiency in comparison to a combined cycle plant. This is due to the loss of energy associated with the steam turbine. Will the output be constant?
    @sarathkumar-FEGRPw • Oct 9, 2013
    How far the loop or the chain of heat recovery steam generator can be used?
    Is cogeneration better than Heat recovery steam generator?
    what can be the application of Heat recovery steam generator in the field of automobile?
