@reya-SMihdC • Aug 22, 2011
Previous year placement questions:
1.void main()
int d=5;
printf("%f",d);
Ans: Undefined
2.
void main()
int i;
for(i=1;i<4,i++)
switch(i)
case 1: printf("%d",i);break;
case 2😛rintf("%d",i);break;
case 3😛rintf("%d",i);break;
switch(i) case 4😛rintf("%d",i);
Ans: 1,2,3,4
3.
void main()
char *s="12345s ";
printf("%d",sizeof(s));
Ans: 6
4.
void main()
unsigned i=1; /* unsigned char k= -1 => k=255; */
signed j=-1; /* char k= -1 => k=65535 */
/* unsigned or signed int k= -1 =>k=65535 */
if(i<j)
printf("less");
else
if(i>j)
printf("greater");
else
if(i==j)
printf("equal");
Ans: less
5.
void main()
float j;
j=1000*1000;
printf("%f",j);
1. 1000000
2. Overflow
3. Error
4. None
Ans: 4
6. How do you declare an array of N pointers to functions returning
pointers to functions returning pointers to characters?
Ans: The first part of this question can be answered in at least
three ways:
1. char *(*(*a[N])())();
2. Build the declaration up incrementally, using typedefs:
typedef char *pc; /* pointer to char */
typedef pc fpc(); /* function returning pointer to char */
typedef fpc *pfpc; /* pointer to above */
typedef pfpc fpfpc(); /* function returning... */
typedef fpfpc *pfpfpc; /* pointer to... */
pfpfpc a[N]; /* array of... */
3. Use the cdecl program, which turns English into C and vice
versa:
cdecl> declare a as array of pointer to function returning
pointer to function returning pointer to char
char *(*(*a[])())()
cdecl can also explain complicated declarations, help with
casts, and indicate which set of parentheses the arguments go in (for complicated function definitions, like the one above). Any good book on C should explain how to read these complicated C declarations "inside out" to understand them ("declaration mimics use"). The pointer-to-function declarations in the examples above have not included parameter type information. When the parameters have complicated types, declarations can *really* get messy. (Modern versions of cdecl can help here, too.)
7. A structure pointer is defined of the type time . With 3 fields min,sec hours having pointers to intergers.
Write the way to initialize the 2nd element to 10.
8. In the above question an array of pointers is declared.
Write the statement to initialize the 3rd element of the 2 element to 10;
9.
int f()
void main()
f(1);
f(1,2);
f(1,2,3);
f(int i,int j,int k)
printf("%d %d %d",i,j,k);
What are the number of syntax errors in the above?
Ans: None.
10.
void main()
int i=7;
printf("%d",i++*i++);
Ans: 56
11.
#define one 0
#ifdef one
printf("one is defined ");
#ifndef one
printf("one is not defined ");
Ans: "one is defined"
12.
void main()
int count=10,*temp,sum=0;
temp=&count;
*temp=20;
temp=∑
*temp=count;
printf("%d %d %d ",count,*temp,sum);
Ans: 20 20 20
13. There was question in c working only on unix machine with pattern matching.
14. what is alloca()
Ans : It allocates and frees memory after use/after getting out of scope
15.
main()
static i=3;
printf("%d",i--);
return i>0 ? main():0;
Ans: 321
16.
char *foo()
char result[100]);
strcpy(result,"anything is good");
return(result);
void main()
char *j;
j=foo()
printf("%s",j);
Ans: anything is good.
17.
void main()
char *s[]={ "dharma","hewlett-packard","siemens","ibm"};
char **p;
p=s;
printf("%s",++*p);
printf("%s",*p++);
printf("%s",++*p);
Ans: "harma" (p->add(dharma) && (*p)->harma)
"harma" (after printing, p->add(hewlett-packard) &&(*p)->harma)
"ewlett-packard"
Source: <a href="https://www.btechguru.com/showSubMenu.php?mid=3&smid=11&ssmid=122&smcid=870" target="_blank" rel="nofollow noopener noreferrer">Careers > Jobs | Placements > Placement papers</a> -
PLacement questions:
Selection process:
The process followed by HCL TECHNOLOGIES was:
1) Written test
2) Personal Interview
Written test
There were three sections in test
1) VERBAL (25Questions- 25min) (Not that much tough)
2) QUANT (25Questions - 35min)
3) TECHNICAL (25 Questions- 35min) (C,C++ knowledge)
4) APTITUDE (25 Questions -35min) (Number series, easy)
Questions asked in interview:
1)Difference b/w C & C++
2) What are advantages of C++ over C?
3) What is POLYMORPHYSM and how can we achieve it in our C++ programs?
4) What will u do if u has a clash with your colleague?
5) If u are given Extra work in the Office and Your girlfriend is waiting for you at the outside. Then what will u do?(Wondering at this question)
6)Why did you choose this engineering trade? -
@pushkar-2u9XqH • Aug 22, 2011
Thanks..
Hey how to handle 5 interview question??
