Harmful radiation by Towers
Tarun Goel
@tarun-TYZzQz โ€ข Oct 26, 2024
as we know that mobile towers radiate harmful products. so i have some thought in my mind that if we put antenna under the ground and a major antenna on the earth. Can then harmful radiation be minimise.
  • Jeffrey Arulraj
    @jeffrey-xA7lUP • Oct 4, 2012
    The same effect will be seen there also
    We some time have a wrong notion that there is no ecosystem under ground
    But the fact is there is a huge underground ecosystem which will be affected by the radiations from towers
    And adding to it there are furthur more complications in transmission methods and stuff like that
  • grsalvi
    @grsalvi-7IhIh1 • Oct 4, 2012
    JEFFREY has considered correct issues.And after all you have no choice but use atmosphere for signal distribution.
  • Jeffrey Arulraj
    grsalviJaffrey has considered correct issues.And after all you have no choice but use atmosphere for signal distribution.
    Pal I am JEFFREY and not Jaffery kindly bare with me in this
    Next your reply
    Tesla transferred AC through ground over a distance of some 100 km if it is possible data transmission is possible but the efficiency is a bit of concern to me
  • grsalvi
    jeffrey samuelPal I am JEFFREY and not Jaffery kindly bare with me in this
    Next your reply
    I didn't mean that the data transmission is not possible via underground. The under ground cables are for that purpose only.
    But for global exchange of data ,i don't think cable method is economic ,hence we use satellites and ionosphere for transmission global.
  • Jeffrey Arulraj
    Ips from the thread starter is needed for continuation of thread
    There are many possibilities if the range is very small then this is good other than that I am help less in this regard
