  • GSM Activated Car Security
    Abbanhaidar
    Member
    Updated: Oct 27, 2024
    Views: 1.0K
    This should be my first thread in this forum(CE).:smile:
    I'm trying to build a gsm activated car security. Will someone tell me where to tap the signal that will activate (trigger) the security on the gsm module when the number inserted on it is dialed? Or may be a better idea. Thank you.
    Abbanhaidar
    Welcome to CE Abbanhaidar,
    Let me know which type of security you want to give in the Car. I mean GSM Modem dials a number whenever any one try to break the door or tempering the ignition system of the car?
  • Abbanhaidar
    MemberJan 10, 2011
    No it is a kind of security that should be used as a last resort, say if the stolen or snatched, you should be able to deactivate the car remotely. It should be part of the security of the car but not everything. Thanks godfather!
    Abbanhaidar
    Oh Yes this is also possible. For that you have to interface the modem with your car's Ignition system and the sparking mechanism now based on the controller which is also interfaced with the GSM modem and whenever your car is stolen then send one SMS with password the GSM MODEM receives that SMS decode it and stops the Ignition system and you can also use GPS for the location tracking.
    I remember that this type of project is completed by our company but it was for BIKE. (I had not worked on this but knows little bit about the same.)
    If you don't mind please give a introduction about you in Introduction Section.
  • mahmoud tarek eissa
    MemberOct 11, 2013
    plz help me staff i want to know how to connect the gsm module with gps module and arduino to make project
