  • 4M4N
    @4m4n-jQmegc • Dec 21, 2010
    Answer:5
    3 and 5 are only numbers that divide 32,162,237 and leave the same remainder. thus 5>3
    Correct me if wrong
  • Deepika Bansal
    @deepika-jf1ysv • Dec 21, 2010
    4M4NAnswer:5
    Correct me if wrong
    Though i dont know the answeres, but i think neither 3 nor 5 can be the answeres to this question. This is so because when 32,162,237 is divided by 3 or 5, we get 2 as remainder.
    But the question says that the remainder should be same as the divisor....
    If wrong, please correct me..
  • Sachin Jain
    @sachin-0wuUmc • Dec 21, 2010
    @Deepika---> Remainder should be same in all cases.....
    Can you please try the same for these numbers : -
    62,132 and 237
    And please post your method also.
    Sorry ๐Ÿ˜”
  • Deepika Bansal
    @deepika-jf1ysv • Dec 22, 2010
    The method which i am following is as:
    If I have to test a number 'x' for the solution then, (32,162,237-x)mod x=0.
    and why are you sorry blunderboy....??
  • 4M4N
    @4m4n-jQmegc • Dec 22, 2010
    @deepika is it compulsory that remainder should always be 0(according to ur method), as we can see remainder in the 1st example is non zero and can be anything
  • Sachin Jain
    @sachin-0wuUmc • Dec 22, 2010
    @Deepika
    I said sorry because i gave wrong numbers first time.
    Actually numbers are 62,132,237.
    I am not getting your solution beacuse its very difficult to find the value of x.
    As far as i think..
  • Deepika Bansal
    Ok now I got it. You mean numbers are 62,132 and 237. I thought its a single number as 62132237.
    Sorry.๐Ÿ˜”
    4M4N now i also think 5 is the answere.......
  • Sachin Jain
    No Guys,
    Its answer is 35.
    62 % 35 =27 (35x1=35)
    132%35=27 (35x3=105)
    237 % 35=27 (35x6=210)
    Now think of its solution.
  • 4M4N
    35 may be answer of 62,132,237 but i solved for 32,162,237 and its answer is :5
  • Reya
    @reya-SMihdC • Dec 22, 2010
    blunderboyNo Guys,
    Its answer is 35.
    How did you find the value of x?
