@kang-q0dzal • Aug 12, 2009
ce_nehaHi
Does windows Vista allow graphics in C using tc,it gives nothing when I run it,inspite of an errorfree code.
If not, then please suggest which compiler should I use?1.Yes graphics in C are fully supported using TurboC (in vista...or any windows)
2. Why don't you post the code?
I personally feel GCC is the best compiler. -
@debu-62iszV • Aug 12, 2009
@ce_neha: I faced a similar problem a while back. Try using <a href="https://www.dosbox.com/" target="_blank" rel="nofollow noopener noreferrer">DOSBox, an x86 emulator with DOS</a> , and you won't face any problem.
Regards,
Debu ๐ -
@saurabh2486-Tr6NOC • Aug 16, 2009
i think debu is right ๐
@sunitsoni-iK2OBk • Sep 4, 2009
debu@ce_neha: I faced a similar problem a while back. Try using <a href="https://www.dosbox.com/" target="_blank" rel="nofollow noopener noreferrer">DOSBox, an x86 emulator with DOS</a> , and you won't face any problem.
Regards,
Debu ๐its also not working it cant include header file
@debu-62iszV • Sep 5, 2009
@sunit.soni: Check your directories. It works perfectly.
Regards,
Debu ๐ -
@sunitsoni-iK2OBk • Sep 12, 2009
debu@sunit.soni: Check your directories. It works perfectly.
Regards,
Debu ๐you are right its works properly๐
