  • Grand Quiz Question #12
    @abrakadabra
    Updated: Oct 26, 2024
    Views: 1.3K
    The 12th Question of the #-Link-Snipped-# is as follows -
    [Worth 10 CE Coins]
    Following is the forecast about the order of the positions in which some participants would finish a race.
    The chart below also indicates how correct the forecast was.
    The Question is : Who won the race? i.e. Who reached the finish line first?
    NOTE: You have to tell us the approach you used to get the answer.
    Race
    First one to answer this correctly wins the coins!
    On your mark... get set... GO!
  • Anil Jain
    MemberNov 12, 2011
    Who won the race?? --A
    Row 2predicted that F will win the race, and row 3 predicted that G will win the race... and its given that none of them predicted correctly for any right position. So, this tells that F and G can not win the race.
    So looking at all 5 predictions, A is the only choice who can win the race.
    -CB
  • hridya
    MemberNov 12, 2011
    Answer is A..
    the options 2 and 3 have 0 right positions.
    thats all the positions are wrong..
    this implies F and G never finish 1st.
    since in options 4 and 5 F and G comes 1st respectively.. we are left with the 1st option.. so A comes 1st
  • Anoop Mathew
    MemberNov 12, 2011
    From the figure,
    1: 2 right positions and one wrong position
    Right: A, E Wrong: B
    2: 0 right and 1 wrong
    Wrong: E
    3: 0 right and 2 wrong
    Wrong: E, C
    4: 1 right and 2 wrong
    Right: B Wrong: F,I
    5: 1 right and 1 wrong
    Right: F Wrong: A
    So A should win the race.
    P.S: I don't understand this line "No of participants finishing in 1st through 5th positions that were predicted". Do you mean 5 positions or 5th position?
  • Varsha0802
    MemberNov 12, 2011
    from the predictions of line 2 and 3, where the predictions right are 0, we infer that neither of d to k are the winners. that means one of the remaining 3 must be the winner. now, since the winner must be on the right place also at the right forecast, only A fulfills it, that is, at the 1st prediction. so A is the winner.
  • silverscorpion
    MemberNov 12, 2011
    From the table, sing trial and error, I came up with the set of 5 persons who actually came in the top 5 positions.
    It came to be "B, C, D, I and F".
    Now, we need to find the order in which they finished.
    Filling these info in the table, we have
    [TABLE="width: 200"]
    [TR]
    [TD]1[/TD]
    [TD]--[/TD]
    [TD]B[/TD]
    [TD]C[/TD]
    [TD]D[/TD]
    [TD]--[/TD]
    [TD]2[/TD]
    [TD]1[/TD]
    [/TR]
    [TR]
    [TD]2[/TD]
    [TD]--[/TD]
    [TD]--[/TD]
    [TD]--[/TD]
    [TD]--[/TD]
    [TD]D[/TD]
    [TD]0[/TD]
    [TD]1[/TD]
    [/TR]
    [TR]
    [TD]3[/TD]
    [TD]--[/TD]
    [TD]C[/TD]
    [TD]--[/TD]
    [TD]I[/TD]
    [TD]--[/TD]
    [TD]0[/TD]
    [TD]2[/TD]
    [/TR]
    [TR]
    [TD]4[/TD]
    [TD]F[/TD]
    [TD]--[/TD]
    [TD]--[/TD]
    [TD]B[/TD]
    [TD]I[/TD]
    [TD]1[/TD]
    [TD]2[/TD]
    [/TR]
    [TR]
    [TD]5[/TD]
    [TD]--[/TD]
    [TD]F[/TD]
    [TD]--[/TD]
    [TD]--[/TD]
    [TD]C[/TD]
    [TD]1[/TD]
    [TD]1[/TD]
    [/TR]
    [/TABLE]
    Now, we know from row 2 and 3 that D is not the last and C and I are not 2nd and 4th respectively.
    From row 5, either F is 2nd or C is last. Assume one of them, and find if everything is coming correctly. Assuming F is 2nd proved to be correct.
    So, the correct order is B==>F==>C==>D==>I
    The original table can be verified with this order to be correct.
    So, B came first.. 😀
  • bodix
    MemberNov 12, 2011
    The sequence is 1st= I, 2nd= B, 3rd= K, 4th= A, 5th= E.
    From forecast:
    1 - Right= B (2nd), E (5th); Wrong= A (should be 4th).
    2 - Wrong= E (...5th)
    3- Wrong= I (...1st), E (...5th)
    4- Right= K (3rd); Wrong= I (...1st), B (...2nd)
    5- Right= A (4th); Wrong= E (...5th).
    Therefore, I won the race... 😉
    AdministratorNov 12, 2011
    This thread is now closed!
