Get Power From Single Table Fan
Shiyam Sundhar.N
Shiyam Sundhar.N
@shiyam-sundharn-eMzlPj Oct 24, 2024
Its Possible to get power from single table fan?
    @thebigk Mar 11, 2013
    Shiyam Sundhar.N
    I'm not sure what you are asking. Perhaps adding more details to your question can help us understand your question better and post our responses. 😀
  • Shiyam Sundhar.N
    Shiyam Sundhar.N
    @shiyam-sundharn-eMzlPj Mar 11, 2013
    The_Big_K
    Without load its possible to get power from table fan
    Shiyam Sundhar.N
    Still not clear, sorry. Don't shy away from writing more 😀 . What setup are you thinking that would lead to generation of power from table fan?
  • Shiyam Sundhar.N
    Shiyam Sundhar.N
    The_Big_K
    No i am not shy. If connect some alternator to backside of table fan. it takes load. For that i need solution .
  • zaveri
    zaveri
    @zaveri-5TD6Sk Mar 11, 2013
    the torque generated by a table fan motor is not sufficient to power an alternator.
    i tried this project once myself.
  • Shiyam Sundhar.N
    Shiyam Sundhar.N
    Hi
    zaveri
    Hi, can explain as detail.
  • zaveri
    zaveri
    Shiyam Sundhar.N
    Hi
    table fan and ceiling fan motors are very low power motors and they are designed with a very low factor of safety, that is to say, that the torque generated by them in Nm is very low and only enough to accelerate the blades which are generally light weight.
    the armature of an alternator however requires more torque, than can be provided by any domestic fan motor.
    so if you mechanically couple the shafts of the fan motor and alternator, the fan motor will stall, due to the high moment of inertia of the alternator armature,
  • lal
    lal
    @lal-R60Xjx Mar 11, 2013
    Do you mean, make the fan motor work as an alternator, by making the motor rotate with the help of blades absorbing energy from wind blowing outside?
    Its an induction motor in most fans. Making induction motor work as a generator is not so easy as with its counterparts with those fan baldes. Induction motors need to be rotated at a speed greater than the rated speed for this to happen. something that is almost impossible with a normal table fan using natural wind as a power source to the prime mover.
  • Shiyam Sundhar.N
    Shiyam Sundhar.N
    @shiyam-sundharn-eMzlPj Mar 12, 2013
    lal
    k i understand can tell some electrical business.
  • zaveri
    zaveri
    @zaveri-5TD6Sk Mar 12, 2013
    Shiyam Sundhar.N
    how about manufacturing fan regulators and calling bells. ?
    it is quite lucrative nowadays.
  • Shiyam Sundhar.N
    Shiyam Sundhar.N
    @shiyam-sundharn-eMzlPj Mar 13, 2013
    zaveri
    Can you detail?
  • zaveri
    zaveri
    @zaveri-5TD6Sk Mar 14, 2013
    Shiyam Sundhar.N
    Can you detail?
    there is nothing much to elaborate over.
