Genetic Algorithms
rajesh
@rajesh-QHnjF0 โ€ข Oct 24, 2024
i want to do a project on genetic algorithms for economic dispatch and optimisation.if anybody knows clearly about this,please give me guidance.
  • pradypop
    @pradypop-Draqkg • Aug 22, 2006
    Genetic Algorithms are a set of algorithms which are frequently used in image processing. These are learning algorithms and are used to approximate a value whose absolute is not known and enough information is not avalilable to compute the absolutes. I worked a little bit on these algorithms when I tried a project on License plate recognition. Never went ahead eith the project which was prematurely dumped.
    This over-view might help:
    <a href="https://en.wikipedia.org/wiki/Genetic_algorithm" target="_blank" rel="nofollow noopener noreferrer">Genetic algorithm - Wikipedia</a>
    @thebigk • Oct 28, 2006
    pradypopI worked a little bit on these algorithms when I tried a project on License plate recognition.
    Prady, tell us more about this project. Looks like a good idea to me.
    -The Big K-
  • Predictor
    @predictor-lfVrRm • Mar 26, 2009
    pradypopGenetic Algorithms are a set of algorithms which are frequently used in image processing. These are learning algorithms and are used to approximate a value whose absolute is not known and enough information is not avalilable to compute the absolutes.
    Although genetic algorithms can be used in image processing, they are used for many other things as well. More importantly, genetic algorithms are not "learning algorithms". Genetic algorithms are, fundamentally, optimizers. While they can be used as part of a learning system, their ultimate function is to optimize some objective function. Their advantage over traditional optimization techniques is that they do not need to know the derivatives of the objective function- in fact, assuming that candidate solutions can be ranked, they do not even require the objective function to be on an absolute scale at all!
    -Will Dwinnell
    <a href="https://matlabdatamining.blogspot.com/" target="_blank" rel="nofollow noopener noreferrer">Data Mining in MATLAB</a>
  • ms_cs
    @ms-cs-Ab8svl • Mar 26, 2009
    rajeshi want to do a project on genetic algorithms for economic dispatch and optimisation.if anybody knows clearly about this,please give me guidance.
    Can you give detailed description of your project?
    See the Book Artificial Intelligence by Stuart Russell
