generator
qaisarpk1
qaisarpk1
@qaisarpk1-6Lfp0G Oct 22, 2024
in simple loop generator when conductor move in magnetic field ,voltages induced in conductor. i am confused abt the position of the conductor. the maximum voltages induces when conductor is perpendicular with magnetic field but if you look the position in books it seems like parrallel both conductor and field. >>>>
  • Ernesha
    Ernesha
    @ernesha-WfrFnu Apr 26, 2009
    <a href="https://dcacmotors.blogspot.com/2009/03/basic-generator.html" target="_blank" rel="nofollow noopener noreferrer">Simple Loop Generator | Electric Motor</a>
    In Fig shows a single turn rectangular copper coil ABCD
    moving about its own axis, a magnetic field provided by either
    permanent magnets or electromagnets. The two ends of the coil are
    joined to two slip-rings or discs a and b which are insulated from
    each other and from the central shaft. Two collecting brushes (of
    carbon or copper) press against the slip rings. Their function is to
    collect the current induced in the coil and to convey it to the
    external load resistance R.
    <a href="https://3.bp.blogspot.com/_Gky8ltNWVFk/Scdorj9_1DI/AAAAAAAAAX0/V8946mHRJ3I/s1600-h/Simple+Loop+Generator+01.JPG" target="_blank" rel="nofollow noopener noreferrer">Simple+Loop+Generator+01.JPG (image)</a>
    Content
    1.Working Theory:
    <a href="https://2.bp.blogspot.com/_Gky8ltNWVFk/ScdoigImKPI/AAAAAAAAAXs/buHzVlILoQc/s1600-h/Simple+Loop+Generator+02.JPG" target="_blank" rel="nofollow noopener noreferrer">Simple+Loop+Generator+02.JPG (image)</a>
    2.Practical Generator
    <a href="https://3.bp.blogspot.com/_Gky8ltNWVFk/ScdockmzzqI/AAAAAAAAAXk/KSTgswS25nE/s1600-h/Simple+Loop+Generator+03.JPG" target="_blank" rel="nofollow noopener noreferrer">Simple+Loop+Generator+03.JPG (image)</a>
    3.Armature Windings
    <a href="https://3.bp.blogspot.com/_Gky8ltNWVFk/ScdoQRasIiI/AAAAAAAAAXc/mDdNEV2Z1Gk/s1600-h/Simple+Loop+Generator+04.JPG" target="_blank" rel="nofollow noopener noreferrer">Simple+Loop+Generator+04.JPG (image)</a>
  • sauravgoswami
    sauravgoswami
    @sauravgoswami-UAfTlI Apr 26, 2009
    the post by ernesha is very self-explanatory,whne the conductor rotates then its perpendicular with magnets and thus maximum coltage is induced!!!
