Generator Stator Earth Fault Relay (64G) - 27TN.
@khaled-hamza-qmyNzA
1.7K
<a href="https://science-hamza.blogspot.com/2010/12/generator-stator-earth-fault-relay-64g.html" target="_blank" rel="nofollow noopener noreferrer">Electricity , Power generation ,Thermal power plant , Solar Energy , Generators , Green Energy: Generator Stator Earth Fault Relay (64G) - 27TN.</a>
-For high impedance grounded generators, a voltage relay across the secondary winding of the generator neutral grounding transformer is used to detect the ground fault on the generator stator winding.
-The neutral over voltage function (59N) responds to the fundamental frequency voltage at the generator neutral that appears when a ground fault occurs.
-Normally, it will protect up to 90â 95 % of the stator windings.
-The neutral under voltage functions responds to 3rd harmonic voltage measured at the generator neutral. When used in conjunction with the neutral over voltage function, it provides 100% ground fault protection of the stator winding.
[FONT="]-In healthy state, the machine 3rd harmonic voltage is distributed over the windings such that the maximum occur at the star point neutral and at the line terminal. For a ground fault close to the neutral, all the 3rd harmonic voltage is transferred to the line terminals. Consequently, the relay function will see a 3rd harmonic under voltage at the neutral end and will operate the protection element.[/FONT]
