  • Generation Of Power Through Footsteps: piezoelectric material
    vikeshrajan
    Member
    Updated: Oct 26, 2024
    Views: 1.2K
    The application of our project is "Generation of power through footsteps". When we walk on the PVDF sheet the charges will be generated on the sides. By keeping two metals on the sides and charge induction, can we trap the charges generated and convert into voltage and store it in a battery.
  • ISHAN TOPRE
    MemberFeb 1, 2011
    That's a great idea.But I think the power generation will be unstable as number of people walking on that sheet will vary,won't it?
  • narayana murthy
    MemberFeb 1, 2011
    @ishu: no ishu i think it may be like using animals do you seen in any movies or any shows
    a rabbit is running on a rotating wheel and we generate electricity
    like wise here humans walk on sheet and some electricity can be generated there may be some problem as you ask but thats not a main problem here as we in this century
    @vik: i think i never heard about that sheet if your sure i am with you to help in anyway
    try for it i am supporting you
    as it is eco-friendly 👍
  • ISHAN TOPRE
    MemberFeb 1, 2011
    @NM:yeah I agree with you that it is ecofriendly but what we need is a reliable source of energy.For example there may be hours when nobody walks on that sheet so power cannot be generated ,can it be?
  • narayana murthy
    MemberFeb 1, 2011
    @ishu: you may be right so we install it in various places and takes energy
    the main role in electricity takes place is how we generated it and how much efficiently we use it
    so in my view we place it in heavy traffic places like where traffic is there at the mid night too
  • ISHAN TOPRE
    MemberFeb 1, 2011
    Ok,Then let it not be a lone source of power.It can be supplemented by conventional sources.
    For example a signal can be run normally with electricity but can be supplemented for by this PVDF sheet.Something like a generator or invertor.😀
  • narayana murthy
    MemberFeb 1, 2011
    Sorry ishu i cant understand what your saying
  • ISHAN TOPRE
    MemberFeb 1, 2011
    You know mixed petrol? In it we mix ethanol+petrol,right?
    Similarly we can reduce load on conventional electricity by supplementing it with PVDF power.
    one more suggestion:Constructing road of PVDF sheet may be little more costly why don't we just use this technology in speed breaker(Imagine an assembly with asomething like a spring below it which somehow generates powerif applied load)? Whenever a vehicle will pass over that speed breaker,It will compress the spring below it thus generating power.
  • narayana murthy
    MemberFeb 1, 2011
    May be your right ishu but there is a problem if we keep it in below speed breaker all vehicles go slowly so,much electricity cant be generated then coming to cost i agree with you a bit costlier so why cant we make the sheet with less cost material
  • vikeshrajan
    MemberFeb 4, 2011
    Hi frnds,We r replacing PVDF sheet by PZT,bcoz its cost is little bit low.
    It generate more power compared to PVDF
  • raj87verma88
    MemberFeb 4, 2011
    I remember seeing this in a documentary about new technology on Discovery. What they did was put piezoelectric material in the footpath. So when people walked, they produced some electricity. This was used to charge nearby batteries and run the street lights, traffic lights, parking meters etc. It was in a shopping complex. And it has been a while since this prokect was started and it is working fine.
    Will try and give you a link about it. Will have to search it first. And if I remember correctly, I think it was in Sweden.
  • narayana murthy
    MemberFeb 5, 2011
    hey can i know the full form of PZT
  • vikeshrajan
    MemberFeb 5, 2011
    @NM:full name is Lead Zirconium Titanite😁
  • vikeshrajan
    MemberFeb 5, 2011
    @raj:I did the project in simulation..............After i finish my simulation, I will send u.........
    Thanks
    Vikesh
  • vikeshrajan
    MemberFeb 5, 2011
    @Raj:Give brief explain, whats in swedan???//////////
  • vikeshrajan
    MemberFeb 5, 2011
    @ishu:Its a non conventional source of energy
  • narayana murthy
    MemberFeb 5, 2011
    @vikesh: thanks i too will think about it
  • ISHAN TOPRE
    MemberFeb 5, 2011
    That's great.Tell if your project is successful.Best wishes😀
  • vikeshrajan
    MemberFeb 6, 2011
    😁Any one have an idea about Piezoelectric transformer
  • raj87verma88
    MemberFeb 7, 2011
    vikeshrajan
    As I said I am not sure whether it was Sweden but I know that it was a European country. They had used the same concept of using a piezoelectric material to generate electricity for use in a local plaza of some kind. The material was fitted in footpaths and as the people walked on it, the resulting stress produced electricity.
  • vikeshrajan
    MemberFeb 10, 2011
    Hi frnds,
    I done my project 'Power generation through footsteps' on MATLAB package,there runtime is very slow almost 2hrs..So we r plan to do it in another package........help us....did any one know software package thoroughly means ,send hou to use..............😒
  • narayana murthy
    MemberFeb 10, 2011
    how about pspice
  • sandi
    MemberFeb 10, 2011
    Not exactly powered by footsteps, but they claim 30kw/hr from normal vehicle traffic...not too shabby!
  • vikeshrajan
    MemberFeb 10, 2011
    @narayana murthy:Ya ,I tried in Pspice but I did not get the result even for first stage..........I tried 2 times,I got a same error............The error faced r
    1.less than 2 connections at node N00782
    2.Less than 2 connections at node N00814
    3.Node Noo782 is floating
    4.Node N00814 is floating
    I will send my first stage ckt.....
  • vikeshrajan
    MemberFeb 10, 2011
    @narayana murthy:I dont know how to copy the ckt diagram........
    The capacitor is in series with voltage source and two reistors
  • narayana murthy
    MemberFeb 12, 2011
    @vikesh: i think it is better to write the program relavent to circuit diagram
  • vikeshrajan
    MemberFeb 13, 2011
    @narayan:how?
  • vikeshrajan
    MemberFeb 14, 2011
    Hi frnds,the output of Piezoelectric material is ac r dc..
  • narayana murthy
    MemberFeb 15, 2011
    program coding like did you seen any pspice books
    they gives codes for every sources like
    source node1 node2 value
    such a coding i dont know exactly how to say
    refer to books for additional data about coding
  • vikeshrajan
    MemberFeb 23, 2011
    The output of piezocrysal is ac........positive going wave is due to compression and negative is due to tensile
  • vikeshrajan
    MemberFeb 23, 2011
    can anybody tell how to boost up the power in a circuit(if the input is dc)............
  • Hari Prasath
    MemberMar 1, 2011
    i hav seen a article based on dis and also seeen dis in discovery channel buddy..
    if possi get more info frm d@..
  • narayana murthy
    MemberMar 3, 2011
    please don't use sms language buddy its illegal here
  • PraveenKumar Purushothaman
    MemberMar 4, 2011
    vikeshrajan
    You can use repeaters to boost... 😀
  • magelec
    MemberMay 23, 2011
    hi ,
    what if we can use hydraulics under the speed breaker
    we install a simple system and use an under ground turbine
    it may be more reliable
    what is your opinion
  • magster
    MemberMay 23, 2011
    maglec that is a good option but the point is where will you put the turbine and how?
  • narayana murthy
    MemberMay 24, 2011
    magster
    i think it can done by making a turbine underground we take a place and we keep a turbine at low level i think this is what he is saying
    @maglac: it may be nice but i think its difficult and kinda costly
    MemberMay 24, 2011
    But are you saying you can place a turbine under a speed breaker???
  • praba230890
    MemberMay 24, 2011
    You can never have such a doubt.....as u know piezoelectric principle when a variable pressure is applied to a piezoelectric material it produces voltage which depends on the amount of pressure applied.The amt of pressure applied is variable as we know so for sure voltage developed is variable which is then A.C.
  • praba230890
    MemberMay 24, 2011
    First of all guys be clear in this thing that we are going to fit the piezo resonator in footwear or in the road, then start design a system. If you want to charge up your mobile phone or any battery while you jogging or walkin i,e personal use you better fit it in footwear and while you want to get a huge power then surely roads.
    Already most of the sensors in railway crossovers which indicate the train's arrival uses piezo resonators to obtain power. I've already done a project on this piezoelectric power generation and i did it for charging up industrial sensor's . If any one wants to over go through my project better ask me i'll send u my report.(<a href="https://mytheoriesarehere.blogspot.com/" target="_blank" rel="nofollow noopener noreferrer">Green it......</a>)
    MemberMay 24, 2011
    That's great... So, what have you decided till now... I mean, the plan?
  • magelec
    MemberMay 24, 2011
    narayana murthy
    what i am sayingis that when a car passes over the speed breaker
    ithe hydraulic piston wil put pressure on the liquid which can then be used to turn a turbine
    this wont cost much
  • narayana murthy
    MemberMay 24, 2011
    magelec
    this wont cost much
    hahaha nice joke is turbine is coming for you at the cost of free to place in underground
    its too difficult at initial and maintainance cost
  • magelec
    MemberMay 24, 2011
    what is funny in that
    it is a full proof system
    and also
    what are taxes for huh
  • magelec
    MemberMay 24, 2011
    please tell me how to start a new thread im new here
  • Ravi Theja
    MemberJul 14, 2011
    vikeshrajan
    I found a paper which would optimize the energy generated.
    Please follow this link.
  • praba230890
    MemberJul 14, 2011
    you got to update yourself..... that is an old method.
    Ravi Theja
  • praba230890
    MemberJul 14, 2011
    Try this #-Link-Snipped-#. I remember reading this paper 4-5months back as a part of my project.
    Ravi Theja
  • narayana murthy
    MemberJul 15, 2011
    magelec
    and also
    sorry for late reply i am saying about cost if it is not payable no one will encourage for it and think if any problem occour in turbine repair is too hard
  • vodin
    MemberAug 8, 2011
    So the voltage has to be regulated as it will be highly variable. What about the circuitry needed for that? and besides, if it is to be stored in batteries dc conversion is needed. How will the need for all this affect the overall efficiency? im talking about cost vs output.
    MemberJan 17, 2012
    Guys, check this out: #-Link-Snipped-#
  • palamarri
    MemberJan 24, 2012
    hey hiiii any one who did the electricity generation with foot steps i need the documentation,circuit diagram urgently....
  • yogesh royal
    MemberSep 14, 2013
    heyy .. i'm on research on generation of power through foot steps ... is there anyone who can assist me ?????
    AdministratorSep 14, 2013
    yogesh royal
    Sure. What help do you need?
  • yogesh royal
    MemberSep 14, 2013
    yeah ... i just now about the principle only , so please tell me about working procedure briefly . As am a student , i would like to make a working model ... so , help me to make it ..
  • narayana murthy
    MemberSep 14, 2013
    principle is simple piezo electric crystals are meterials which convert mechanical energy intlo electrical energy.
    That means how much stress you produce on them that much energy will be generated.
    And limits will be depended on crystal quality
  • yogesh royal
    MemberSep 14, 2013
    narayana murthy
    okey .. Narayana murthy ,but , i wanna know about construction view .. cuz i wanna show in practically.. howi can i make a working model
  • yogi.bharadwaj
    MemberOct 3, 2013
    Guys you have a great topic.but is efficiency is less but as the @#-Link-Snipped-# says if we can assemble more tricks then we may be able to run this idea.for eg. everybody knows about solar energy but it is not at night,you guys talks about pizoelectric transformer but it has less efficiency,we can use solar panels on walls which uses the bulb emitted light again etc.now the benifeats are i think a solar pannel has life about 8-10 years and we should paint walls approx. 2 times a year then the coast may be settled or not.the solar energy can't be at night but if we store it in dc form then can be used at night and the footprints energy also can be stored.so
