how the negative voltage is generated using positive for some application0
Member • Jan 30, 2010
we can generate it by using the less positive voltage as negative wrt some reference...but i dont know if we use the positive voltage of same amplitude...if anybody have any idea than please give some hint...Are you sure? This action cannot be undone. -
This can be simply obtain by using an operational amplyfier in its INVERTING MODE of operation.sonujainhow the negative voltage is generated using positive for some application
you just have to feed the positive votlage to its input and the desired negative voltage will be produced on at its output.
correct me if i am wrong.Are you sure? This action cannot be undone. -
but nitsy we aslso need negative volage in operational amplifier to operate it this is not possible....Are you sure? This action cannot be undone. -
I dont think we need such thing,sonujainbut nitsy we aslso need negative volage in operational amplifier to operate it this is not possible....
may be i am not getting you properly,
but if we provide the positive voltage to the inverting terminal of the op-amp and keep the non inverting terminal at ground or some reference voltage, then the output for such configuration with op-amp will result in negative voltage.😒Are you sure? This action cannot be undone. -
hey i guess..if you simply shift the origin..by using the opamp ic...but sorry i dont remember exactly the name for that circuit ..but ya it uses opampAre you sure? This action cannot be undone. -
it is inverting mode of operation in op-amp,piyushhhey i guess..if you simply shift the origin..by using the opamp ic...but sorry i dont remember exactly the name for that circuit ..but ya it uses opamp
as i explained before.Are you sure? This action cannot be undone. -
ya yaa.i read that..but am not talkin about inverting modeAre you sure? This action cannot be undone. -
to operate opamp we need both negative and positive voltage here we have only positiveAre you sure? This action cannot be undone. -
ok thnx i gotAre you sure? This action cannot be undone. -
sorry i got iwa confusedAre you sure? This action cannot be undone.
