  • ShrinkDWorld
    @shrinkdworld-WWdBBc • Feb 11, 2010
    I think we have better material than C.I.
    So that it is more useful
  • jyotimoon09
    @jyotimoon09-HuYdNP • Feb 11, 2010
    this in not a proper answer.
    please justify your answer
  • jyotimoon09
    please give me a proper answer because i have to submit assignment on this question.
  • gohm
    @gohm-F3UUpP • Feb 11, 2010
    Although you can cast iron via methods like sand and foam, it does not lend itself well to die casting due to the properties of iron. Highly fluid Non-ferrous alloys work much better for high pressure mold injection. Die casting also has thickness and weight limitations which also makes iron less than ideal.
  • 070790vivek
    @070790vivek-09g1Yf • Feb 11, 2010
    i think gohm is right
    die casting needs some special faetures for better moulding
    i think that for mass production we use cold die casting
    and the %of carbon present in C.I. creates some problem in such a very less time for moulding and it has to face high pressure
  • saimriyaz
    @saimriyaz-n5uQmu • Jun 15, 2011
    due to its properties............
  • RVignesh
    @rvignesh-GKAYUU • Jun 17, 2011
    CI is best suited where there is compressive forces only , but in case of die casting there are other forces also . Moreover the actual materials used for die casting like Zn etc have properties a lot different from CI hence the other materials are better suited and CI is not used
  • sumit gupta
    @sumit-gupta-QuN0xk • Jun 22, 2011
    bcoz cast iron is brittle material thats why it can not use fr die casting
  • TejaNaidu
    @tejanaidu-xaiQIR • Jun 27, 2011
    we can use cast iron for die casting.But it gives less strength when subjected to compressive forces and poor characterstics in matarial...thatsway we cant.
