GATE 2012 Computer Science Questions With Solutions
1. An organization has a class B network and wishes to form subnets for 64 departments. The subnet mask would be
- 255.255.0.0
- 255.255.252.0
- 255.255.128.0
- 255.255.64.0
2. Let G be a simple graph with 20 vertices and 100 edges. The size of the minimum vertex cover of G is 8. Then, the size of the maximum independent set of G is
- More than 12
- Less than 8
- 12
- 8
3. The order of an internal node in a B+ tree index is the maximum number of children it can have. Suppose that a child pointer takes 6 bytes, the search field value takes 14 bytes, and the block size is 512 bytes. What is the order of the internal node?
- 24
- 26
- 27
- 25
4. The minimum number of page frames that must be allocated to a running process in a virtual memory environment is determined by
- page size
- physical memory size
- the instruction set architecture
- number of processes in memory
5. The best data structure to check whether an arithmetic expression has balanced parentheses is a
- list
- tree
- stack
- queue
6. Suppose the round trip propagation delay for a 10 Mbps Ethernet having 48-bit jamming signal is 46.4 ms. The minimum frame size is:
- 464
- 94
- 416
- 512
7. Consider the following C program
main ()
int x, y, m, n ;
scanf (“%d %d”, &x, &y); / * Assume x > 0 and y > 0 * /
m = x; n = y ;
while ( m ! = n)
if (m > n)
m = m + n;
else n = n – m ;
printf(“%d”,n);
The program computes
- x mod y using repeated subtraction
- the greatest common divisor of x and y
- the least common multiple of x and y
- x + y, using repeated subtraction
8. The minimum number of page frames that must be allocated to a running process in a virtual memory environment is determined by
- page size
9. Consider the following C function:
int f (int n)
static int i = 1;
if (n >= 5)
return n;
n = n + i;
i++;
return f (n);
The value returned by f(1) is
- 5
- 8
- 6
- 7
10. A Priority-Queue is implemented as a Max-Heap. Initially, it has 5 elements. The level-order traversal of the heap is given below: 10, 8,5,3,2 Two new elements 1 and 7 are inserted in the heap in that order. The level-order traversal of the heap after the insertion of the elements is
- 10,8,7,3,2,1,5
- 10,8,7,5,3,2,1
- 10,8,7,1,2,3,5
- 10,8,7,2,3,1,5
11. The following numbers are inserted into an empty binary search tree in the given order: 10, 1, 3, 5, 15, 12, 16. What is the height of the binary search tree (the height is the maximum distance of a leaf node from the root)?
- 2
- 4
- 3
- 6
12. The relation scheme Student Performance (name, courseNo, rollNo, grade) has the following functional dependencies:
The highest normal form of this relation scheme is:
- name, courseNo -> grade
- rollNo, courseNo -> grade
- rollNo -> name
- name -> rollNo
Support your answers with explanation.
