Fuzzy logic with engineering applications solutions manual 3 edition?
yuosef
@yuosef-Af3drp โ€ข Oct 27, 2024
hi , any one can you help me to get fuzzy logic with engineering applications solutions manual 3 edition????
thanks you
  • zaveri
    @zaveri-5TD6Sk • Feb 18, 2014
    yeah sure. The entire thing may cost you $899.00 plus tax.
    @thebigk • Feb 18, 2014
    Here it is: <a href="https://www.amazon.com/Fuzzy-Logic-Engineering-Applications-Timothy-ebook/dp/B000SBAWM2" target="_blank" rel="noopener noreferrer">Amazon.com</a>
  • yuosef
    yuosef OP
    @yuosef-Af3drp • Feb 19, 2014
    the book it founded and free if you want it i will uplaod it . but i want the solutio manuals for it (fuzzy logic with engineering applications 3edition ) free without many
    thank you
  • benin
    @benin-mRtjSJ • Aug 29, 2015
    i need this problem solution
    In a gas system there are two basic properties of gas ( Temperature and Pressure) that can be used to determine whether calculations for the system can be done using the ideal gas law or if a more robust property package is required. The ideal gas law applies to the system with high temperature (T) and low pressure (P). The drawback of employing a more robust approach is that the computational requirements increase tremendously.
    P (atm) , T (k)
    1 , 400
    1.7 ,370
    1 , 280
    9 ,300
    9.5 ,280
    Classify the given set of data for P and T into two classes to determine which system requires a robust property package for thermodynamic calculations.
    Use m' = 2 and e = 0.01 for the following
    a) Hard C -means
    b) Fuzzy C -means
    c) Find classification metric
    d) Find the similarity relation using the U - partition from Part (b)
  • sameena_553
    @sameena-553-oNDNRy • Dec 23, 2015
    i also need this book solution manual. I do not find it anywhere
