FPGA 5V TTL to control 9.5V 1A motor
Holly
@holly-OPYdEj โ€ข Oct 22, 2024
Hi!
I have an assignment that I need some help with, I hope this is the right place for it.
I'm completely new to this kinda thing and I've spent about 4 whole days trying to figure this out.
The assignment reads:
Design a circuit that will let you control a engine that runs on 9.5V and 1A thru an output on an FPGA (Nios2DE) that leaves 5V 1mA TTL.
I have to build 4 of these on a budget of about $3.
I've figured as much as I need to use transistor(s) as a switch.
I've been doing some calulations, but I don't get it to add up.
Please help!
Thanks!
/Holly
  • gohm
    @gohm-F3UUpP • Mar 25, 2009
    Can you share your calculations for us to see?
  • Holly
    Holly OP
    @holly-OPYdEj • Mar 25, 2009
    That's the thing, I don't quite understand everything, so I'm not sure HOW to do the calculations. ๐Ÿ˜ณ
    These are the designs that I've come up with:
    [โ€‹IMG]
    In this case what I want is for the transistor to be fully saturated. This would be, if I can find a transistor that will be saturated with an Ib=1mA.
    The transistor should be able to handle a minimum of 1.5A.
    The more likely scenario, if I have understood that much, is this:
    [โ€‹IMG]
    Please help me figure this out! ๐Ÿ˜’
    Thanks!
    /Holly
