four numbers such that the sum of every two numbers & sum of all four numbers may be perfect square
2.I have a wooden cube 3 on a side and a buzz saw.The cube can be cut into 27 one inch cubes by the buzz saw.Only 6 cuts of saw are necessary to make 27 one inch cubes keeping the pieces of cubes together.Can you reduce the no of cuts by rearranging the piecess after each cut??If yes, how is it done??If no,why cant it be done??
3. Find the largest possible number containing any 9 of the 10 digits considering 0 that shud be divisible by 11, without a remainder??
4.Can you rearrange the position of the numbers 1 to 10 so that the sum of any two adjacent numbers is equal to the sum of the pair of numbers at the opposite ends of the diameters??
