@zaveri-5TD6Sk • Sep 15, 2012
One approach is, to first determine the forces that will act on the screws and thus the stresses that they will induce.
now whenever the the fan starts from rest, the weight of the blade, due to inertia, exerts a shear force on the screw. thus this induces shear stress in it.
now the centrifugal force, due to rotation of fan, too may be inducing stresses in the bolt. thus the bolt material can be chosen so as to withstand the maximum of the two stresses.
is this right ? #-Link-Snipped-# #-Link-Snipped-#, what do you have to say to this. -
@ramani-VR4O43 • Sep 15, 2012
You are right about the forces you indicated.
The blades are usually asymmetric. This leads to a difference in the force acting on the two fixtures (The blades are usually riveted). The drag caused by the blade moving the air creates additional shear. The downward thrust of the air flow tries to push up the blade. This leads to a tensile force. This should be considered at the highest speed of the fan. When the fan is stationary the weight of the blade acts downward in ceiling fans. This also creates a small tension. -
@jeffrey-xA7lUP • Sep 15, 2012
each action has opposite response this i think provides the balancing effect to the centripetal and other forces acting in the screws of the fan -
The opposite action in this case are the shear and tensile forces described above. The fixture should take these forces with an adequate factor of safety.jeffrey samueleach action has opposite response this i think provides the balancing effect to the centripetal and other forces acting in the screws of the fan -
thank you sir -
@ce-designer-BWq0yl • Sep 17, 2012
#-Link-Snipped-# both you and ramani covered the loading criteria pretty well. Free body diagrams always help me.
