folder lock
abhimanipal
@abhimanipal-G68SgB Oct 26, 2024
well there is a particular folder whose contents i want to hide...people suggested i download some software for this....but one of my friends suggested i can do this by changing the extension of the file......however he could not explain the method very clearly....
can any one of you guys throw some light on this topic ?????
  • Jerry
    @jerry-5wPKU7 Dec 15, 2006
    Isn't that simple? If you are on WinXP, right click on the folder which you want to hide, Go to 'attributes' and select 'Hidden'. This will make the folder and its contents hidden.
    In the same way, you can hide any file. I hope this solves your problem.
    @thebigk Dec 15, 2006
    Sounds Good. I think this thread best fits in our IT - Help section. Will move it after to that section.
    -The Big K-
  • Prasad Ajinkya
    @prasad-aSUfhP Dec 15, 2006
    There is this software called as folderLock, which I think you are referring to. Simple software, password enabled. It sits in your system tray. You can choose which folder you want to hide/lock, et al. Specify access levels and what not.
    I guess the s/w is pretty self explanatory and intuitive. Wont sing paeans about its features here, thats for you to find out.
    Oh, did I mention that its a licensed software 😁
  • Jerry
    @jerry-5wPKU7 Dec 23, 2006
    kidakakaThere is this software called as folderLock, which I think you are referring to. Simple software, password enabled. It sits in your system tray. You can choose which folder you want to hide/lock, et al. Specify access levels and what not.
    I had used a similar freeware, but I don't remember the name. I think it can be a good project for our CE Labs
    Jerry
  • Prasad Ajinkya
    @prasad-aSUfhP Dec 24, 2006
    I also remember that there was some entry in the windows registry which when deleted hides all your drives ...
  • aashima
    @aashima-eO93l9 Jan 3, 2007
    Well other than using a seperate sofware, MS DOS can also be used to lock a folder using the rename command. But it can work only when its only YOU who knows the trick because it can be unlocked by anyone not being password sensitive.
  • T`u`L`!`P
    @tulp-2Fw39M Mar 17, 2007
    dear..
    u can do it by built-in windows compressing tool.. no need for any software... but if u want some.. m using a very handy tool called "Hide File Folder" a good thing and by using this ool u can get an option in ur context menu for hiding any file or folder, so no pain, no tension, no long procedure...
    juss right click on ur file and click "protect by HFF".... by this u can make ur folder password protected , totally invisible and only hide its name.. and many other options...
    .... but mostly ppl dont like 2 use any s/w so will suggest u 2 use buit-in feature.....
    here is the link: <a href="https://www.softstack.com/hff.html" target="_blank" rel="nofollow noopener noreferrer">Hide Files & Folders</a>
    its key: <edited>
    regards
    @thebigk Mar 17, 2007
    T`u`L`!`Pdear..
    here is the link: <a href="https://www.softstack.com/hff.html" target="_blank" rel="noopener noreferrer">Hide Files & Folders</a>
    its key: <edited>
    regards
    Tulip,
    I checked out the website and found that the software is not a freeware (or is it?). Providing key is surely an illegal activity. Please confirm a.s.a.p.
    I request all new CEans to go through the CE Common Sense Guide ( <a href="https://www.crazyengineers.com/index.php?categoryid=20">CrazyEngineers</a> ) before beginning journey with other CEans.
    -The Big K-
  • T`u`L`!`P
    @ above... thx,
    here are the links
    regards
  • manjucv
    @manjucv-DMR0sC Mar 26, 2008
    this is the easiest way without any software click below link
    <removed>
  • suyash
    @suyash-2N6gPP Mar 27, 2008
    just for curiosity, is it Folder Guard?
    and unlike you, I can't quote the last line in your post with respect to my usage of the same software 😁... but its good for sure !!
  • soul_hacker
    @soul-hacker-QZaoNw Apr 9, 2008
    i agree with my colleges. better to use folderlock software to hide ur content.
  • Ashraf HZ
    @Ash Apr 9, 2008
    An indirect method would be to use an encryption software like truecrypt. Its pretty good.. and free 😉
  • sanalgrover
    @sanalgrover-kzLITm Feb 2, 2009
    Jst right click on the folder u want to hide and move on to properties and there change the icon to a blank one.
    Then again right click on the blank icon and move on to rename. After this keep Alt key pressed and then press 255 from numpad. This will change your folder name to blank.
    Now u should be aware of the location of the folder becoz the folder will be completely invisible. Now if u want u can even hide it through properties to provide extra protection.
    Hope dis solves ur problem, if does then do rply!!!
