FM conversion
awaiting
awaiting
@awaiting-ipQI42 Oct 7, 2024
hello guys,
i would like to know whether it is possible to upconvert a 100MHz frequency modulated signal to 900MHz using an upconverter ic
  • shreyasm89
    shreyasm89
    @shreyasm89-jGobVm Sep 17, 2010
    Ok...but all you need is a mixer which will use heterodyning & have 3 o/p's. Sum of frequencies, difference frequency & the original frequency, but you will need an i/p frequency from an oscillator.This could help you.....#-Link-Snipped-#
  • awaiting
    awaiting
    @awaiting-ipQI42 Sep 17, 2010
    instead of using a mixer will an upconverter ic do?,
    i dont know much about the mixer theory so if its possible i'd like to go directly for an upconverter ic
  • shreyasm89
    shreyasm89
    @shreyasm89-jGobVm Sep 18, 2010
    Its pretty difficult to get such an IC.In most of the cases though you will have to provide another i/p frequency.
  • awaiting
    awaiting
    @awaiting-ipQI42 Sep 19, 2010
    i know of a few ic's like max2660-max2673
    and LT5519 <a href="https://www.alldatasheet.com/datasheet-pdf/pdf/102484/LINER/LT5519.html" target="_blank" rel="nofollow noopener noreferrer">LT5519 Datasheet(PDF) - Linear Technology</a>
    but i dont know if these can be used to upconvert a frequency modulated signal to higher frequencies!
  • shreyasm89
    shreyasm89
    @shreyasm89-jGobVm Sep 20, 2010
    Yes even I'm not sure because the FM signal will contain the carrier as well as the harmonics.
