Flywheel Control
zaveri
zaveri
@zaveri-5TD6Sk Oct 23, 2024
Now consider a situation :
a very flywheel is mounted on the spindle of an electric motor, and the motor rotates at its highest speed. now the flywheel is designed in such a way that if the motor is turned off, the flywheel will cause the spindle to rotate at the same high speed for atleast half an hour, after the power to the motor is cut off.
now suppose we want to turn off the motor and want the spindle to stop at the same time, without using any mechanical brakes, how can this be achieved electrically ?
  • Kedar Malwadkar
    Kedar Malwadkar
    @kedar-crbktt Jul 21, 2012
    The question is really interesting, there should be some way!
    Have you found anything?
  • zaveri
    zaveri
    @zaveri-5TD6Sk Jul 21, 2012
    i have considered that instead of just turning off the motor, we can reverse its polarity, so that the opposite torques cancel each other.
    what do you think about it ?
    Ramani Aswath
    @ramani-VR4O43 Jul 21, 2012
    There is no escape from Newton's first law of motion.
    So the first thing to do is to use a magnetic clutch and disengage the flywheel from the spindle. If the motor is a low inertia, printed circuit motor, a magnetic brake will stop it quickly. Even then there could be some delay due to even the small inertia of the spindle.
  • zaveri
    zaveri
    @zaveri-5TD6Sk Jul 22, 2012
    bioramani
    yeah that is true, the motor spindle will have some inertia.
    all that i wanted to achieve is stop the flywheel from performing its function.
