Flux when speed of induction motor exceeds synchronous speed
pinank
pinank
@pinank-6TUo5O Oct 22, 2024
what will happen to the flux when an induction motor is run at speeds greater then synchronous speed? will the motor supply reactive power to the supply to maintain the constant flux?
  • pinank
    pinank
    @pinank-6TUo5O Jan 13, 2013
    #-Link-Snipped-# please help me with this!
  • lal
    lal
    @lal-R60Xjx Jan 14, 2013
    When an induction motor rotor is made to run above the synchronous speed, it will inject electrical energy back to the supply. That is, the machine will start acting as a generator. In fact this method is sometimes used in regenerative braking.
    When the rotor rotates at a speed greater than synchronous speed, the flux produced by the circulating current in the rotor will induce an opposing voltage in the rotor and make a reverse current flow back to the supply. At this time actually the torque and slip are negative. In this mode the mainflux will reduce, I think, as a reverse current is fed back.
    Why do you think a reactive power will be injected back?
