@capt-spark-xvppcH • Jul 8, 2011
see the amount of the torque to be transferred. if it is not so high, key / spline may be fine.
for high torque transfer, flange is better. It give a support at higher radius with higher shear allowable, and hence more torque capacity. -
@mr-zakaria-MV45kb • Jul 8, 2011
The max estimated torque to be transferred is 64 Nm.
The wheel has a diameter of 200 mm and width of 80 mm.
I'm not sure whether this amount of torque can be considered as high or not.
In terms of robustness, which fixation is easier to be done?
Thanx -
@capt-spark-xvppcH • Jul 9, 2011
Key is definitely a simple arrangement. And with this numbers, I think the calculation goes like this:
F=64000N-mm/100mm=640N
shear stress s = 640N/(80mm*5mm)=1.6 MPa (assuming 5 mm wide key) which should be OK.
Plz check once if you find any loophole in the calculation -
@saimriyaz-n5uQmu • Jul 11, 2011
I think coupling will be the best option.............................
@capt-spark-xvppcH • Jul 11, 2011
why so?
flange coupling needs complex modification to the shafts and is obviously a costlier arrangements with bolts.
Do you find any reason why it is better than the simple key mechanism? -
It is because coupling like of universal joint let your wheel move in any direction................you can adjust motor location, can transfer high amount of torque .
Yet they are costly but they provide variety of operation. -
[video=youtube;cfg8jb6CWq0]https://www.youtube.com/watch?v=cfg8jb6CWq0[/video]
check this out..................... -
@capt-spark-xvppcH • Jul 13, 2011
true.. I agree completely.
If there is any chance of even a little misalignment, a flex coupling is a must
