Find the output of the following C Apptitude (2)
rengaraj
@rengaraj-89Rrct โ€ข Oct 26, 2024
Sir / madam,
My question is
void main()
char *s="\12345s\n";
printf("%d",sizeof(s));
Advance Thanks,
R.Rengaraj
{Java Certification Quiz}
{On this forum my 22nd Question.}
  • sarveshgupta
    @sarveshgupta-txtmu5 • Dec 6, 2009
    Can you please tell that don't we specify char with ' ' rather than " "
    is it because we have taken it as a char pointer
    seeing as if it can be said that the output will be 6
    Is it the right answer?
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD • Dec 6, 2009
    The variable s is a pointer to a string. (its because of "").
    The answer may be 4 as any pointer is 4 bytes long (correct me if I'm wrong).
  • dipen30
    @dipen30-hGOPpa • Dec 6, 2009
    compile this code and run it.
    It gives the output 2.
    can anyone explain how the output is 2? char contain 1 byte.
  • rengaraj
    @rengaraj-89Rrct • Dec 6, 2009
    sarveshguptaCan you please tell that don't we specify char with ' ' rather than " "
    Sir,
    How you say the output is 6 ? can you please explain.
    R.Rengaraj
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD • Dec 7, 2009
    dipen30compile this code and run it.
    The output depends on the compiler you use. 16 bit compilers store the pointers as 2 byte entity.
    Which compiler you used?
  • sarveshgupta
    @sarveshgupta-txtmu5 • Dec 7, 2009
    rengarajSir,
    R.Rengaraj
    Actually i counted the characters in the string
    As we are calculating the length of the string so i counted the length of the string
    but if we see for a normal char we know that in java char occupies 2 bytes
    so if it has to consider char the output should be 2
    Am I right?
  • dipen30
    @dipen30-hGOPpa • Dec 7, 2009
    I am using 16-bit compiler. so it gives output 2?
  • Saandeep Sreerambatla
    @saandeep-sreerambatla-hWHU1M • Dec 7, 2009
    dipen30I am using 16-bit compiler. so it gives output 2?
    Yes the pointer is 2 bytes irrespective of the type it is pointing to.
    Depends on the compiler though.
    Yes Gaurav said 16 bit gives 2 bytes.
    32 bit gives 4 bytes.
  • gaurav.bhorkar
    E_S is exactly right. A pointer is 2 bytes long in 16-bit compilers, and 4 bytes long in 32-bit compilers.
    @sarveshgupta: Remember, it is not a character string, its a pointer to a character string.
  • sarveshgupta
    Ok gaurav.. thanks
  • dipen30
    @dipen30-hGOPpa • Dec 8, 2009
    thanx gaurav & E-S
  • rengaraj
    @rengaraj-89Rrct • Dec 8, 2009
    Sir,
    Have anybody tested on the compiler ???
    I hope the solution will be 6.
    R.Rengaraj
  • aishwarya mk
    @aishwarya-hnVUq3 • Jul 10, 2016
    answer is 2
    because char data type 1 byte for * and another byte for s(address of array)
