Find sum of two numbers
uday.bidkar
@udaybidkar-JNYtYq • Oct 22, 2024
#include<stdio.h>
int main()
int i;
printf("Enter 2 numbers\n");
Write here few lines of code so that user gives 2 numbers as
input(on console) and display the addition of those 2 numbers.. and
the condition is no more variable(s) except for 'i' declared in first line
should be used throughout the program.
return 0;
Regards,
Uday
  • sahana
    @sahana-S4nL10 Mar 10, 2007
    hi,
    i have used the consecutive memory location of i to store the 2 data.this works.
    #include<stdio.h>
    #include<conio.h>
    void main()
    int i;
    scanf("%u",&i);
    scanf("%u",&i+1);
    printf("%d",(*(&(i)))+(*(&(i)+1)));
  • uday.bidkar
    @udaybidkar-JNYtYq Mar 11, 2007
    sahanahi,
    #include<stdio.h>
    #include<conio.h>
    void main()
    int i;
    scanf("%u",&i);
    scanf("%u",&i+1);
    The memory pointed to &i+1 is not valid memory that you can use for operations as you have not allocated the same neither asked compiler to allocate it for you on stack. Hence the program may crash because of invalid memory operations. So solution not acceptable!
    -Uday
  • DEP
    DEP
    @dep-Xne9ZU Mar 12, 2007
    uday.bidkarThe memory pointed to &i+1 is not valid memory that you can use for operations as you have not allocated the same neither asked compiler to allocate it for you on stack. Hence the program may crash because of invalid memory operations. So solution not acceptable!
    -Uday
    hi uday,
    i have tried a lot to solve this problem and believe me whether you accept it or not pointers is the only way to solve it.
    i guess i quite agree with the solution provided by sahana and am unable to figure out any other solution.
    so please post any other solution if you have it !!!
  • uday.bidkar
    @udaybidkar-JNYtYq Mar 14, 2007
    DEPhi uday,
    There is a way to solve this. But before i post the answer for this, I would like to relax the condition and wait for few more days.
    And the relaxed question is
    #include<stdio.h>
    int main()
    input(on console) and display the addition of those 2 numbers.. and the
    condition is only one integer variable should be declared and used
    throughout the program. You are now free to declare the variable as you want.
  • DEP
    DEP
    @dep-Xne9ZU Mar 14, 2007
    uday.bidkarThere is a way to solve this. But before i post the answer for this, I would like to relax the condition and wait for few more days.
    #include<stdio.h>
    int main()
    int *a;
    cin>>*a;
    cin>>*(a+1);
    cout<<*a+*(a+1);
    well uday i am sorry but this is the only solution that i have worked out.and i guess this is the c++ equivalent code of what sahanna had posted.
    please please please tell the answer. am dying to know it.
  • uday.bidkar
    DEPplease please please tell the answer. am dying to know it.
    Here is answer to the problem when variable is not
    already declared.
    int main()
    static int i = 0;
    if( !i )
    i = -1 ;
    printf( "The Sum is %d\n", main() + main() ) ;
    return 0 ;
    printf( "Enter a number\n" );
    scanf( "%d",&i );
    if( !i )
    i = -1 ;
    return 0 ;
    else
    return i ;
    Regards,
    Uday
  • sahana
    @sahana-S4nL10 Mar 16, 2007
    wow.that was really smart.
    i accept my mistake.well actually i actually got the output ,as i was lucky that the unallocated memory was not a part of anyother program, and didnt overwrite any data of another program.
  • Satyajit
    @satyajit-nC3BSF Mar 16, 2007
    hi i have the programme of sum of 2 numbers
    #include<stdio.h>
    void main()
    int a,b,c;
    printf("enter any 2 numbers");
    scanf("%d%d",&a,&b);
    c=a+b;
    printf("%d",&c);
    @thebigk Mar 16, 2007
    Satyajithi i have the programme of sum of 2 numbers
    #include<stdio.h>
    void main()
    int a,b,c;
    c=a+b;
    printf("%d",&c);
    Satyajit, mind reading the first post in this thread? There is a special condition to be followed.
    -The Big K-
  • uday.bidkar
    @udaybidkar-JNYtYq Mar 19, 2007
    Time to post the answer and here it is...
    int main()
    int i ;
    printf("Enter two numbers\n");
    printf("Sum is %d\n",(scanf("%d",&i)?i:0) + (scanf("%d",&i)?i:0));
    return 0 ;
    Regards,
    Uday
