@ramani-VR4O43 • Jun 15, 2016
Raw sewage is 99% water, total contaminants being about 1%. Almost all conventional treatment plants tackle this as a whole. If you can come up with a means of segregating at least insoluble contamination at source and process that separately it could be a big help.
How about designing distributed air filtration systems that are self cleaning, use solar or wind power and remove bulk of the suspended particulate matter at near ground level? -
@akarsh-pillai-UgQ4oN • Jun 16, 2016
A.V.RamaniRaw sewage is 99% water, total contaminants being about 1%. Almost all conventional treatment plants tackle this as a whole. If you can come up with a means of segregating at least insoluble contamination at source and process that separately it could be a big help.
How about designing distributed air filtration systems that are self cleaning, use solar or wind power and remove bulk of the suspended particulate matter at near ground level?Process the sewage water without insoluble solid? right?
Will u tell me more about air filtration system -
@ramani-VR4O43 • Jun 16, 2016
Where are you located, AKARSH? Where are you doing your Chem engg course?
A.V.RamaniWhere are you located, AKARSH? Where are you doing your Chem engg course?
Pune. Sinhagad College Of engineering,vadgaon.
Good.
Is this a team activity? Is it a proof of concept activity or a full scale actual equipment to be built? Who funds expenses? Do you have a departmental guide? What are his/her views on what areas should be looked at? -
A.V.RamaniGood.
Is this a team activity? Is it a proof of concept activity or a full scale actual equipment to be built? Who funds expenses? Do you have a departmental guide? What are his/her views on what areas should be looked at?It is a 2 member group. Concept activity. We are not assigned with departmental guide right now. but departmental guide will be assigned in 2-3 days. Right now I am deciding what to do for my BE project
Consider a stand alone modular air filter that can remove >2.5 micron suspended particles using a low cost fabric filter, similar to those used in vacuum cleaners, industrial bag filters and such.
The intake should be at a lower level. Filtered air can be delivered at a higher height. Short circuiting between intake and output must be avoided by design.
The parameters like static air pressure to push the required volume of air through a half choked filter, some mechanism to dislodge and collect the collected debris on the fabric and ease of maintenance should be considered.
It may be best to design it for 220 V AC operation. If alternate energy like wind or solar is used a suitable energy collector and converter can be used. The project should not include the design of these sources.
Kick the idea around with your team mate and then present it to the guide.
Have you looked at a purely Chem E project such as a simple process for making something like tamarind powder or such? -
@akarsh-pillai-UgQ4oN • Jul 5, 2016
A.V.RamaniConsider a stand alone modular air filter that can remove >2.5 micron suspended particles using a low cost fabric filter, similar to those used in vacuum cleaners, industrial bag filters and such.
Have you looked at a purely Chem E project such as a simple process for making something like tamarind powder or such?Could you help me selecting manufacturing process of compounds? like tamarind powder
@ramani-VR4O43 • Jul 6, 2016
CFTRI Mysore developed a process for Tamarind powder. While teaching in the Chem Engg department at IIT Madras in 1962-69, I myself did some studies on spray drying of Tamarind powder.
For your project you can perhaps look at producing a thick pulp concentrate rather than a powder. Using the de-seeded fruit and warm water first make a thick pulp, remove solids by centrifuging and concentrate preferably by vacuum evaporation to a viscous paste. This may be quite stable because of the low pH and may not need any added preservatives. This will be cheaper than spray or drum dried powder. Capital costs and manufacturing is likely to be cheaper than powder production.
Please discuss with the concerned team mates and guide.
The process for powder making can be seen here:
#-Link-Snipped-# -
Some more info:
UNIT OPERATIONS IN FOOD PROCESSING#-Link-Snipped-#
Tamarind Concentrate
#-Link-Snipped-# -
@akarsh-pillai-UgQ4oN • Jul 10, 2016
So we should vary the operating condition and mass for performing this experiment? so as to find the optimized condition?
@ramani-VR4O43 • Jul 10, 2016
It is the formal guide under whom you are going to conduct this project, who should tell you how to go about. Since full technology development may not be your aim, some sort of proof of concept at lab level should do. You have to specify for yourself the specs for the end product. Size and volume of external material acceptable, viscosity of the product if a paste and shelf life without preservatives can be some of the variables. Shelf life may be difficult in the time available.
You may have to optimise the filtration steps, vacuum evaporation conditions and such.
