File handling storage issue in c++
Vicky One
@vicky-one-9xiLwc โ€ข Oct 26, 2024
i want my random number genereted on the selection bases of vowel or consonent, should be stored in a file permanently on hard disk the below code creates a file but does not store any thing, what should i do? i tried in different ways like without using global variable "f" or declaring the file opening code in both the functions independently insted of a single code in main but all that did not work, file is created but nothing stored.
#include<iostream.h>
#include<conio.h>
#include<string.h>
#include<stdlib.h>
#include<fstream.h>
int hun();
int thou();
char f;
int main()
    char in,x;
    cout<<endl<<"Please enter the alphabet"<<endl;
    cin>>in;
    x=in;
if (x=='a'||x=='e'||x=='i'||x=='o'||x=='u')
  hun();
else
  thou();
ofstream out;
  out.open("D:\\alphabet.txt");
  if(!out)
      cout<<"Error opening file";
  else
      exit(1);
  out<<f;
  out.close();
int hun()
{ int seed;
seed=4;
srand(seed);
for(int i=1; i<2; i++)
  int res1=rand()%((100+1)-(1))+1;
  f=res1;
  cout<<"                            "<<res1;
  if(i%2==0)
  break;
return f;
int thou()
{ int seed;
seed=10;
srand(seed);
  int res2=rand()%((2000+1)-(1000))+1000;
f=res2;
  cout<<"                            "<<res2;
   if(i%2==0)
  break;
  return f;
  • Anand Tamariya
    @anand-tamariya-DnfjEX • Oct 2, 2013
    else
    exit(1);
    Is this really necessary? You're closing the filestream before writing anything to it.
  • Vicky One
    @vicky-one-9xiLwc • Oct 2, 2013
    Well there is no issue bcz of exit(1); removing it also doesnot store the value.. Can u make it to work??
  • rahul69
    @rahul69-97fAOs • Oct 2, 2013
    Vicky OneWell there is no issue bcz of exit(1); removing it also doesnot store the value.. Can u make it to work??
    First of all, whenever u share your code, write it inside [ code ] tags, as it is better to read.
    Secondly u should indent your code, so that it gets easy to understand.
    Now as u said that u wanted "random number generated", then why have u declared f as char? Shouldn't it be int ?
    Also Anand is right, u have used exit() function at wrong place.
    So make these corrections, and see if u get the right output ๐Ÿ˜€
    Good Luck!
  • Anand Tamariya
    @anand-tamariya-DnfjEX • Oct 3, 2013
    You need to learn about variable scope and precedence. You are modifying local variable but writing global variable to file.
  • Vicky One
    @vicky-one-9xiLwc • Oct 4, 2013
    Well thx a lot.. I had done that like this....If any suggestion for this code like code repetition problem or any thing else u think is not right then please comment it here for more perfection.....overall it worked as required.
  • Vicky One
    #include<conio.h>
    #include<fstream.h>
    #include<stdlib.h>
    int vowel();
    int constt();
    int main()
    char x;
    cout<<"Please enter an alphabet"<<endl;
    cin>>x;
    if(x=='a'||x=='e'||x=='i'||x=='o'||x=='u')
    vowel();
    }else
      constt();
    int vowel()
    {  char word[500];
    srand(time(0));
    int res1=rand()%100;
    ifstream in;  //Data from Hard to Ram
    in.open("F:\\abc.txt");
    while( !in.eof() )
    in.getline(word,500);
    ofstream out;  //Data from Ram to HArd Disk
    out.open("F:\\abc.txt");
    out<<word<<" "<<res1;
    cout<<res1;
    int constt()
    char word[500];
    srand(time(0));
    cout<<res2;
    ifstream in;
    while(!in.eof())
    out<<word<<" "<<res2;
