@manishks-AZybhs • Dec 17, 2011
i have read some where that apis avaiable for devlopment of application in fbml is meant for facebook only...whatever is embedded in fbml is meant for facebook only.....well they dont use html i suppose....
fbml provides certain tools like fb.comments etc...they all can be used to develop fb applications only...
@kr-at-nsngu-XqzcfU • Dec 18, 2011
update from developers.facebook.com:
We are deprecating FBML. On Jan 1, 2012: FBML will no longer be supported on Platform. June 1, 2012: FBML apps will no longer work. All FBML endpoints are removed. If you are building a new application on Facebook.com, please implement your application using HTML, JavaScript and CSS. You can use our #-Link-Snipped-# and #-Link-Snipped-# to embedded many of the same social features available in FBML. -
@praveenkumar-66Ze92 • Dec 18, 2011
FBML is just like another JavaScript Library, which allows you to use Facebook specific functions at your ease. For eg, if you want to integrate a Like Box to your HTML (am not talking about the iFrame version), you would need to write a lot of codes like, bringing the Facebook's content to your HTML via AJAX and try to give the same colour and appearance. But what if you can do them with predefined stuffs, built by the Facebook people themselves? FB JS API is one, which does the same and FBML is a specific Markup Language, which translates into JavaScript at runtime, easing the work of the Developers. ๐
@thebigk • Dec 18, 2011
Well, my question might be stupid: If it's a JS library, why is it called a 'markup' language?
@manishks-AZybhs • Dec 18, 2011
sir what is js library ?
The_Big_KWell, my question might be stupid: If it's a JS library, why is it called a 'markup' language?
Not a stupid question, but a right one. If you are going to use the FBML, you are not going to type JavaScript. Instead, you will be writing the FBML Syntax, which is in no way related to JavaScript. The JS API, then translates the content to the native JS for running! ๐ Hope this clears.
musicfreakmandysir what is js library ?
It is a huge collection of good functions, which are ready to use. ๐ For instance, if you want to make a fade effect using JavaScript, in the (g)olden days, before jQuery (a JavaScript Library) came, we used to do this way:
<script type="text/javascript"> var TimeToFade = 1000.0; function fade(eid) { var element = document.getElementById(eid); if(element == null) return; if(element.FadeState == null) { if(element.style.opacity == null || element.style.opacity == '' || element.style.opacity == '1') { element.FadeState = 2; } else { element.FadeState = -2; } } if(element.FadeState == 1 || element.FadeState == -1) { element.FadeState = element.FadeState == 1 ? -1 : 1; element.FadeTimeLeft = TimeToFade - element.FadeTimeLeft; } else { element.FadeState = element.FadeState == 2 ? -1 : 1; element.FadeTimeLeft = TimeToFade; setTimeout("animateFade(" + new Date().getTime() + ",'" + eid + "')", 33); } } </script>Whereas now, with the help of jQuery, a powerful JavaScript Library, you can achieve the same effect by:
<script type="text/javascript" src="https://code.jquery.com/jquery-latest.js"></script> <script type="text/javascript"> $(element).fadeOut("slow"); </script>Did you understand the use of library?
so it is java script library were functions are predefined...we jist have to use them....by java script you are referring to java language only which is basically derived from c++...isnt it?
one more thing if we use html5 then also we cant use java script isnt it????
Java is totally different from JavaScript. Java is by Sun (Oracle). But JavaScript is by Netscape! Just check out the differences between Java and JavaScript here:
https://www.htmlgoodies.com/beyond/javascript/article.php/3470971/Java-vs-JavaScript.htm https://www.dannyg.com/ref/javavsjavascript.html https://en.wikipedia.org/wiki/JavaScript
musicfreakmandyone more thing if we use html5 then also we cant use java script isnt it????
HTML5 extensively uses JavaScript, if you don't know! ๐
ok then we dont use applets in html5 which is basically developed using java language which is developed by sun......but html5 uses javascript which belongs to net scape.....????
am i correct?
musicfreakmandyok then we dont use applets in html5 which is basically developed using java language which is developed by sun......but html5 uses javascript which belongs to net scape.....????
Applet has been stopped using since XHTML 1.1!
musicfreakmandyam i correct?
Right! If you would like to add small content of post, please edit the post. ๐ Don't bump, Biggie might not like! ๐
