factors determining color of led
pratap singh, upendra
@pratap-singh-6xlmve โ€ข Oct 16, 2024
Hi,
does the color emitted by a LED depend on the current passing through it or it merely depends upon the material used for fabricating the LEDS..
Also enlighten me if there are some other factors that govern the color emitted by LED.
regards,
Proffy.
    @thebigk • May 23, 2012
    If I recall properly, the semiconducting material used in the LED determines the color of the LED. Not entirely sure about whether current has any influence on it; logically, it shouldn't.
  • aarthivg
    @aarthivg-HH344f • May 23, 2012
    There are two main types of LED, AlGaInP ( red, orange and yellow )and InGaN ( white, green and blue). Changing these composition, LED color can be changed
    @harshad-ukH5ww • May 23, 2012
    The_Big_KIf I recall properly, the semiconducting material used in the LED determines the color of the LED. Not entirely sure about whether current has any influence on it; logically, it shouldn't.
    You have sharp Memory ! Yeah Light Emission from LED is depend on the Material used in LED and intensity is depend on the current passes through LED.
    Cool. I'm being driven away from my roots ๐Ÿ˜’. Yes, the intensity would clearly depend on the amperes passing through. It'd however be interesting if the current could factor in determining the color of LED. What say? ๐Ÿ˜€
    The_Big_KCool. I'm being driven away from my roots ๐Ÿ˜’. Yes, the intensity would clearly depend on the amperes passing through. It'd however be interesting if the current could factor in determining the color of LED. What say? ๐Ÿ˜€
    Color which is visible to us from LED is depend on the energy radiated by electron when it comes back to stable orbit. And Unstable Orbit may change based on the silicon material used in LED so Light emission is depend on the difference between Unstable Orbit and Stable Orbit.
  • pratap singh, upendra
    @pratap-singh-6xlmve • May 24, 2012
    Hi,
    please tell me how the intensity of an led is dependent on the current passing through it
