fabrication project necessary
prem
@prem-YRNZg1 โ€ข Oct 25, 2024
hi people i am relatively new to this forum... i m a third year mechanical engineering student . can you people please suggest me any good fabrication project which can be done in a low cost...
i do expect a few suggestions
cheers
prem
  • sri
    sri
    @sri-KZNE8A • Jul 2, 2008
    ya go for changing the shaper tool post actually it cuts square n rectangle blocks try to modify the equipment n change it
  • swaroop2003
    @swaroop2003-wvm69v • Dec 7, 2008
    design a pneumati circuit for an existing application and compare ur design with the existing design and list out the advantages of ur design
    @thebigk • Dec 7, 2008
    swaroop2003design a pneumati circuit for an existing application and compare ur design with the existing design and list out the advantages of ur design
    I think your post is irrelevant to the discussion. Could you post your question in appropriate section of the forum?
  • RUCHI JAIN
    @ruchi-jain-ZCNbwk • May 7, 2009
    Go for the Robotics Project that is ,by using single stepper motor which controls two motions with single motor . Use Hostpitals Bed & make it to be automatic by using Stepper motor,controls headrest & tailrest motion.It require nearly 12-13,000.
  • zorif
    @zorif-NVUQGT • Jun 8, 2009
    yeh.need more details what u want exactly.
    even making a metal stand using 4 L-channels and one welding machine will come under fabrication project ๐Ÿ˜€
  • Tkelly
    @tkelly-CKF896 • Jun 11, 2009
    First elaborate on this fabrication project.
    Should it involve sheet metal, bending, shearing, welding?
    If it is the case, then take project for manufacturing small electrical control box.
    Tom
    <a href="https://www.indovance.com" target="_blank" rel="nofollow noopener noreferrer">CAD Outsourcing Services India | Indovance Inc</a>
  • prem.kumar
    @premkumar-TTK5eq • Jun 18, 2009
    hai prem .my name is also prem .prem kumar.what r u doing .were r u studying?ok if u want my friendship u can reply.
  • balamech123
    @balamech123-wkM2cz • Jun 28, 2009
    hi prem , you can do lathe attachment of internal grinding.
    ball mill
    in fabrication project it important that you device ur design skill and fabricate and donot worry that it is already done or machine is already prsent .
