experimental set-up equipments
Jeppi
Jeppi
@jeppi-J46UyF Oct 10, 2024
need to construct (at least a concept) a set-up equipment for investigation of abrasive blasting parameters, namely impact angle and the impact distance (from the tip of nozzle to workpiece). This equipment needs o be removable and fit into sand blasting cabin.any ideas?! 😀😀
    Ramani Aswath
    @ramani-VR4O43 May 1, 2011
    Since the test piece has to be a plain sheet/coupon for such an investigation, all that one needs is an inclined plane that can be fixed at the desired distance from the nozzle at varying angles. A simple version of the sine table used with milling/grinding machines will work.
    Bioramani
