  • exhaust gas
    baldu111
    Member
    Updated: Oct 25, 2024
    what will happen if exhaust gas from a main engine of....say a bike is passed onto another cylinder and fresh air is introduced into that cylinder...(the main engine and the cylinder are coupled)......my doubt is cant there be a possibility for an expansion in this second cylinder due to mixing of air and exhaust...hence a work can be produced from the second cylinder....thereby increasing main engine efficiency and reducing pollution....{this idea of mine could sound weird..but that's why i am sharing it with you...share your ideas too}
  • ShrinkDWorld
    MemberJan 25, 2010
    I can't get the question
  • Vega
    MemberJan 26, 2010
    Then how would your exaust gas generated at every stroke will get a space to accomodate. The result of your action will be that the engine will not eaither start or if started, will stop after couple of cycles.
    Why don't you try it? Prepare a closed chamber with inlet and attach that inlet to silenser exhaust of your vehicle.
  • typex
    MemberJan 27, 2010
    what are you expecting to happen? Don't really get the question either.
